Yeah, you spoke about something you didn't know about as if you did, you then made snooty egotistical claims that you find it unlikely that Hyundai would give a lifetime battery warranty (WRONG) because
nobody does that (WRONG) according to you, the great ill informed spewer of opinionated nonsense; you then Googled something and found a statement by Hyundai from
2017 that said
previous models had a limited warranty, used your immense intelligence to conclude the word "previous" stated by Hyundai in
2017 somehow logically applied to a
2019 Kona Electric (WRONG), and finally, you
repeatedly ignored the
actual language of the
actual warranty for the
actual car we're discussing. And then claimed you won the argument (WRONG - and, frankly? Also painfully pathetic).
You were wrong, literally, about everything you spewed about the warranty - so at least you're consistent and were also wrong about having "won the argument" . By the way, just for the record, it's not about winning an argument for me. It's about being factually correct. It's about being informed before you speak, or, clearly indicating you're just giving an opinion on a matter. It's about admitting if you make a mistake and most of all perhaps learning from it. For example, I realize it was a mistake to try and be polite with you at first, that was a waste of time. You clearly are someone that does not need to have politeness wasted on them.
You know, opinions are fine in some cases. "The Ceramic Blue is the best color of the available Kona Electric choices" - right place for an opinion. Facts that are unquestionably true - not really the right place for an opinion. Let me put it to you this way. Even if every single person on the planet said "In my opinion the sun revolves around the earth" you know what? The earth still would revolve around the sun. Because that is a fact and your opinion on it is completely
irrelevant. Likewise, the warranty for the battery being lifetime is a
fact. The Warranty
not being limited is a
fact. The warranty
not saying it applies only to complete failure of the battery - also a
fact. Your opinion on those matters?
Irrelevant. Your inability to comprehend this:
Sad.
But back to learning from mistakes. I would hope that you would learn not be so snooty when someone mentions a
fact like the Kona Electric comes with a lifetime battery warranty (how about instead of the short and rude "unlikely" you try something like: "I find that hard to believe, can you point me to something that shows they have a lifetime warranty on the battery?") - but that level of politeness is too much to expect from someone with an ego 5 times bigger than your brain, isn't it? I think we both know the answer to that. Everyone knows the answer to that.
Finally ... let's quote the Hyundai Kona Electric website one more time, which is all the proof I need that you were and continue to be
wrong about
everything you claimed about the warranty on the battery (to put it in your terms: this means I won the argument) :
The Lifetime Electric Battery Warranty applies to all U.S. 2019 model-year Kona Electrics. The Lifetime Electric Battery Warranty ensures that if the lithium polymer battery fails, Hyundai will replace the battery and cover recycling costs for the old battery free of charge to the original owner.
