Would you change your mind of there is a specific sign and time limit for EV only? This EV spot is for charging only. I just took this picture on the way back from lunch.View attachment 4174
On which, my stipulation that an official vehicle probably won't be ticketed if they parked there and not an EV? Probably!
Or that you were in a restricted area?
Think of it this way; a girl's dorm has a rule outside that says no boys allowed after 10 Pm; this is for the entire dorm area. Inside the dorm, a pool is accessible until 2 AM; this is specifically for the pool. Can a Boy be allowed in the pool at 1:30 AM? Can a Girl be in the pool at 2:30? Different rules that applies to different situations within the the dorm, but one is more comprehensive than the other. In your case, the restriction applies to the entire parking lot, including the EV station.
Forget that this was City Hall. Remember that those parking slots are for employees. If this was in the building that You worked at, and you Knew your parking lot was restricted to employees only (and in the cities, likely more restricted than just a sign), would you be surprised if a non employee got a ticket for parking inside (or as I said, get twed)?
But this isn't about your or my opinion. We live around the same area, and you probably know as much as I do how literal those parking signage are. They do it so there's no ambiguity on what needs to be followed at any given time or place. In your case, that sign did not say the rules applied to only to weekdays, for example, which means it's in effect even on a Sunday.
