Getting ready to go on a road trip. What are y our experiences using just HV or HV Charge. I know that in charge mode that I will get about 50mi on initial charge and then for each mile driven in charge mode I'll get about a mile EV. So on a tank of gas (7gal) at 40mpg, I should get about 600 miles unless the mpg drops off.
What I dont know is how HV mileage might work out. Any data?
Thanks.
Trying to figure out your math here....
7 gallons at 40 mpg = 280 mile range, not 600!
Basically drive the car. Look for gas before you get to 250 miles on a tank or you’ll be stranded...be careful in rural areas with few gas stations. The small tank notably limits your range compare to other normal cars, which I found to be an occasional annoyance on the road.
And do NOT trust the range estimates in the dash. They will be exaggerated and could leave you in danger of running out of fuel and battery if you rely on the numbers. I came darn close in rural Nebraska once and rolled into gas station on fumes before I realized how inaccurate the numbers are. Also realize the mpg figure is exaggerated on the dash too. You’ll see if you manually track your fuel consumption.
I did a 4,200 mile road trip all across the country in my Clarity. 40 to 42 mpg is realistic long term average over the long haul, you’ll get more mpg if you drive below speed limits, and quite a bit less if you exceed speed limits and run 80 mph most of the way. The car was most economical by far in the mountains, the steeper the better because even though the engine screams uphill, the other 50% of the time the engine is simply shut off and giving you free charges in the downhills...I saw legit 55 to 60 mpg on some up and down mountain runs over a full tank of fuel. And I got as low as 28 mpg on a tank tearing acoss the Great Plains in flat ground at 80 to 85 mph into a strong headwind.
Obviously you’ll be in HV mode most of the time. HV charge mode works fine, but notably reduces mpg, so I saw no point in it.
I never once saw or felt a reduction in power driving up many miles long 12,000 ft mountain grades even with a depleted battery showing 2 bars, not charged for days and thousands of miles, and never activating HV Charge mode even once. I’m not sure why that loss of climbing power thing gets repeated here so frequently, unless there are that many defective Clarities running around. I certainly never experienced it and I fully pushed the limits of this car on that trip, not driving for fuel economy or battery preservation at all...
Do expect some engine revving on long high speed trips. Especially up hills and into headwinds at high interstate speeds. Normal, harmless, and expected.
Enjoy your trip, wherever it is!!
