Curious as I've always resented the 'warranty' because it meant I couldn't make mods until it was over. I do buy my own maintenance manuals(*) and revel in doing the work. For example:@bwilson4web who . . . I hope, he is learning how to fix his Model 3 car by himself.
- Adding 1.1 kW inverter to 2003 Prius
- Adding 2.5 kW inverter to 2010 Prius
- Optimizing tires on 2003 Prius, not the standard size
- Microcontroller for 2003 Prius to reduce cold weather running of engine
- Replacing transmission vent plug with tubing to air cleaner, clean side
- Upgrading traction battery to use more modern modules
- Verified we can rehydrate Prius modules and achieve greater than new capacity
- Replaced rear view mirror with combined GPS and rear camera
- Used shims to achieve perfect rear wheel camber and toe
- Used camber bolts to achieve perfect front wheel camber
- Replaced backup light with one that has an audio beep
- Replaced passenger seat with a 'nap' board
- Added 2" receiver hitches to every car
- Multi-year, multi-car transmission oil study
- Plotted the mph vs MPG for every car
- Performed 'out of gas' study on every car we've owned
- Drive using dynamic cruise control on every car in all traffic
- Conducted vortex generator study of 2003 Prius (sedan body)
- Used pressure caps on cars without tire pressure sensors
- Towed 2,000 lbs of trailer and load 600 miles through a Nor'Eastener
- Extensive use of OBD diagnostic interfaces
- Modified BMW to use European style settings
- Check for bwilson4web in PriusChat.com, the Yahoo Group "Prius Technical Stuff", and the BMW owner's forum. Older, there are entries in GreenHybrid.com and Ecomodder.com.
* - today it is a technical service, online.
