Great for range and mileage but terrible for ride and safety. I too had to let out a bunch of air to get my tires to 36 psi.Drove about 125 miles in overinflated tires.
Was going to check at delivery but forgot. Then wanted to do it when the tires were cold. Finally did it this morning.
All four tires set to 50psi
That's how Honda ships their cars. I've speculated the high tire pressure is likely used to minimize the ability of the car to move around when it's locked down using the oval holes where the infamous rubber plugs are supposed to be installed by the dealer.Why are they all set to 50-psi?
Why are they all set to 50-psi? Mine was the same.
Seems like it is not just one or two dealers doing this. Are the cars leaving Japan that way, or is someone at the port of entry using a bad tire gauge when they prep the cars unloaded from the ship?
Or could it be that Honda sent a bulletin to the dealers advising them to set tire pressure that high for who knows what reason?
As customers who have just spent a shitload of money, are we being unreasonable to expect the local dealer to have a clue, or to give a damn? I am not a "car person" so this is the only place where I would see complaints along this line, but is this a pervasive problem with all brands and all models, or is it limited to the Clarity? I suspect that there must be some sort of pre-delivery inspection step with all cars, but maybe for PHEVs the items are more visible so that the new owner realizes that they have not been done. Maybe the folks who are satisfied with the support they're getting from their local dealers are simply silent here, but my impression is that the vast majority of folks who do speak up only have negative things to say. I don't have any way to measure Honda's interest in this topic.We at that point get mad and complain about on the internet and to the NHTSA thinking it will make a difference because the get off my lawn gene seems to run deep for a clarity owners
Count your blessing that you were one of the few exceptions to the rule.I feel the pain and concern of others whose Clarity's were sold and delivered to their customers with high pressure in the tires and missing body plugs, and other unacceptable prep. I was very lucky that my dealer, Leith Honda in Southern Pines, NC, seems to have followed the pre-delivery instructions carefully, so I was spared that agony.
My dealer did Only the 12 v battery check and proper tire pressure, but was happy to do the plugs and Battery Capacity Signal test when I pointed it out to them. Mine was the first Clarity they sold and the Clarity specific PDI came out the next month so I forgave them.
I read in a thread that Honda over inflates the tires to prevent them from developing a flat spot when being either strapped down or sitting on the lot for several weeks or months. Made sense to me. Imagine how it would feel test driving a new car with a flat spot you could feel as you got the speed up. I did find mine at 50psi also.That's how Honda ships their cars. I've speculated the high tire pressure is likely used to minimize the ability of the car to move around when it's locked down using the oval holes where the infamous rubber plugs are supposed to be installed by the dealer.
