Thanks, I don't follow the latest fuel cell technology but at the end was description of a home hydrogen station described here:
https://insideevs.com/ivys-simple-fuel-hydrogen-station/
If you want to set up your own hydrogen refueling station, just talk to IVYS. The Massachusetts-based company is promoting its Simple Fuel station as an easy, relatively affordable (if you’re a fleet operator, any way) box that can pump compressed hydrogen fuel into your vehicle while only needing a power source, a water inlet, and a vent mast exhaust pipe. If you’ve got those things – and the $250,000-$300,000 that a Simple Fuel station costs, depending on options – you’re good to go.
To figure out how much time it takes to produce a kg of hydrogen, you can just do simple math. So, for the machine that makes 10 kilograms of hydrogen a day (all of these numbers will be based on the top-of-the-line, 700-bar, 10-kg unit, the SF-70-10), it takes 2.4 hours to make one kilogram of H2. That kilogram requires a total of 68.4 kWh of electricity to make. About 55 kWh are needed to electrolyze the water, and the rest is used for compression and operating features. Lastly, a kilogram of hydrogen needs just under a gallon of water (3.8 gallons, or 14.4 liters). And that’s RO standard (reverse osmosis) water in this case.
Now we have some numbers:
- 68.4 kWh / kg :: hydrogen generation electrical cost
- 274 mi ~= 68.4 kWh / 25 kWh/100 mi :: Prius Prime EV miles for 1 kg H{2}
- 236 mi ~= 68.4 kWh / 29 kWh/100 mi :: BMW i3-REx, EV miles for 1 kg H{2}
Mirai specs:
- 62 mi / kg ~= 312 mi / 5 kg :: Mirai fuel tank capacity and EPA range
- 62 mi ~= (62 mi / kg) * 1 kg / 68.4 kWh :: Mirai EV miles
Please double check my work. It looks like home electrolysis generation, compression of hydrogen, and use in a Mirai is ~4 times less efficient than using the same 68.4 kWh to charge batteries in a BMW i3-REx or Prius Prime.
