Ray B
I had noticed a limitation in the regen in the past when getting off the highway, that it wouldn't go to 4 chevrons above ~55 mph. It would blink and drop to 3 chevrons. Once I slowed below that speed the 4th chevron would stay.
But I found a few days ago in ECON mode (no engine use, EV only) that the level of recharge I was getting from the paddles was pretty limited (maxing out at halfway to the first tick on the recharge spedometer thingy); even when applying the brakes a little more aggressively. Granted it was a winter day, but not overly cold outside (~36F/2C?) and the car is kept in a garage, so a little warmer than ambient temperatures overnight. There was ~10 miles used since the charge, so it was probably at ~75-80% SoC. And the car should have been fairly warm with the heater and general battery/motor use.
I know there have been long discussions about triggering the engine when regenerating at very high SoC, but I am finding that the regen is limiting itself now in the winter (even in mild temperatures), and/or between 80 and 95% SoC. At lower SoC I didn't seem to have that regen limitation anymore and the paddles and brakes could bring the charge spedometer all the way to the bottom of the gauge.
Not a complaint, but just something I had noticed for the first time after 4 months of driving it. Presumably, it uses more of the disk brakes when I hit the brakes when the level of regen is limited. Something to keep in mind over the colder months.
I just read the relevant section of the manual:
"In the following situations, the stage may not change and the stage number will blink even if you pull back the selector. The deceleration stage may decrease or cancel automatically:
Not sure if anyone else has noticed this regen limit in cold temps and/or at moderately high SoC.
- The high voltage battery is fully charged or its temperature is too cold or too hot
- The speed of the vehicle is beyond the deceleration range with SPORT mode off
- Hybrid system protection is needed
- The paddle selector is operated while your vehicle is stopped automatically by ACC with LSF
