Yori Lacroix
I'm from Montreal and I bought my Clarity in September 2018 and installed my EV charger in about the same period. The EV charger is from Chargepoint model CPH25-L25. From September to middle pf November, I had no issue to charge the battery with my EV cgharger. However, since midlle of November, when the temperature is -5 deg C and lower, I'm unable to charge the battery with my level 2 charger. However, it works with my level 1 charger or any other level 2 charger (public station). If the temperature get higher than -5 deg C, no problem. My level 2 charger works...... I called Chargepoint. For them, it is not the charger because when I plug the charger on the car, the charger led becomes blue, indicating that the charger is detecting the car and ready for charging. On the car, the green led does not turn on or flashing. It seems that the car does not detect the charger. On my Honda link application, I do not see the connection. However, if I try to drive the car when the cable plugged, the message appears to disconnect the car..... It means that the car detects tge charger connection.... I called the dealer and explain to him the problem. The answer: It is normal. You cannot use this car below -10 deg Celcius.... The honda dealers does not know nothing about the Clarity.... Honda Canada provided only 1 or 2 Clarity per dealer in 2018....
Is anybody have seen this problem? Is it the EV charger (chargepoint) or the car??
Thanks
Thanks
