ProspectiveBuyer
What's the recommended grade of gasoline for the Clarity? One dealership service department said the highest grade. But when I purchased the car, they said regular is fine. Any thoughts?
While I agree that the pressurized fuel tank is a big help for keeping the fuel fresh, I would have to disagree that “no moisture can possibly get in there”.As for fear of moisture or whatever in the tank? The Clarity has a very unique pressurized fuel system. No moisture can possibly get in there, so it's a non-issue to be concerned with.
Agreed that the moisture issue concerns the entire supply chain, not just what's in the tank once the cap is put back on. Having said that, I also have no idea of the scale of any moisture problem and what, if anything, it doesWhile I agree that the pressurized fuel tank is a big help for keeping the fuel fresh, I would have to disagree that “no moisture can possibly get in there”.
One, every time you fuel up you open the tank slightly to ambient humidity and two, ethanol is hygroscopic (loves or absorbs water) and any ethanol blended fuel will necessarily have some small amount of moisture. And the pressurized fuel tank cannot remove this moisture. This is why I avoid ethanol blends like the plague.
craze1cars
Pure gas burns more efficient then diluted gas. Plain and simple. Whether or not it makes a noticeable difference in the Clarity mpg or longer term engine health is still TBD...IMHO.
Have a good day.
As a note about water contamination of ethanol, water will contaminate gasoline just as easily and can cause running problems. Since ethanol attracts water it is actually useful for removing water from the fuel system. It could get phase separation, under storage but only if vented to the atmosphere, which it is not in the Clarity. The only time it could have this is upstream, but they have means of dealing with it at stations.
Phase separation is more likely at lower % ethanol, so it is actually more likely to get phase separation in your 1% ethanol non ethanol fuel than your 10% ethanol fuel.
Something like 95% of fuels in the US contain ethanol.
Indycars run E85 (85% ethanol, 15% gasoline). One reason is advertising for ethanol as the midwest is a major producer of corn for ethanol. The main reason is that pure ethanol burns with a flame that is hard to see, especially in daylight. Adding some gasoline to the fuel makes for more visible fuel fires. E85 will continue to be used in Indycar for at least the next couple of years:Agree entirely. 100% Ethanol is 33% less efficient than 100% gasoline. This means there is almost exactly a 3% loss of power and fuel economy when comparing E-10 to pure gasoline.
I use this math frequently when rejetting and drilling out passages on those old muscle car carbs...it burns leaner and therefore the engines on those cars require larger fuel flow to maintain correct air-fuel ratio on E-10 vs the pure gasoline they were designed to run on. Fuel injected cars do this adjustment automatically with computers on-the-fly, but the 3% loss is still there.
And I'll throw out a point of irrelevant trivia -- Indycars run on 100% pure ethanol with no gasoline. They just cram 33% more of it thru the fuel injectors to get the power out of them.
Good to mention.
Indycars run E85 (85% ethanol, 15% gasoline). E85 will continue to be used in Indycar for at least the next couple of years:
https://racer.com/2018/12/07/indycar-to-stay-with-e85-fuel-through-2020/
LeoP
Agreed that the moisture issue concerns the entire supply chain, not just what's in the tank once the cap is put back on. Having said that, I also have no idea of the scale of any moisture problem and what, if anything, it doesBut, having said that, my local station sells ethanol free top tier premium for 0.30 cents more than regular, which does have up to 15% ethanol. For better MPG and to eliminate alcohol/moisture problems, I use premium. It's cost me only $4.50 for doing that for the entire time I've owned the car.
And I'm sure I've been getting 0.000001 better mpg.
Agreed. Amazing the things you learn here that have nothing to do with the Clarity.It’s amazing how across all vehicle forums the way to ignite postings and bring out an almost religious fervor related to car care is to ask either “Which gas should I use?” or “Which oil should I use?” In this thread we already have 18 posts on something that’s right in the Owner’s Guide, page 118. That’s cool; I already learned something (Indy cars use E85!).![]()
