Bummer... Thank you guys. My dealer knew very little about the PHEV I bought, they even tried to skip the tire inflate kit and pump that was supposed to be included with the purchase till I asked them for it...
Mine also measured at 50 psi on all 4 wheels, reduced them to 36 psi and re-initiated TPMS calibration.Huh? that should be in the rear right compartment. I believe it comes there from factory. If they took it out...
You may also want to check the tire pressure on your car. Many had them delivered at 50psi.
I have wondered before why Honda has these plugs installed by dealer rather than installing them as part of car assembly. Anybody know why they do it that way?
Hi all, short time lurker here. I think mine is missing the body plugs. Can someone confirm please?
I can't tell from that photo. The hole will look like this. Do you have the four rubber plugs. Mine were also not installed. I found them in a plastic bag with the front license plate holder. I almost threw them away.
I think I am looking at wrong area. I went by the diagram posted on another thread.
