How often are you supposed to change the oil on a PHEV?
The salesman told me the engine has an oil viscosity sensor. That would be a good solution but all I have is his word on the subject. I see comments online about a Honda Oil-Life monitor and a number of comments about how the system works. They are all different and seem like guesses to me. At any rate it certainly doesn't make sense to use the car's odometer.The owner's manual says to replace the oil every 1 year or when the car tells you to, whichever comes first. This is for US, Canadian items are on the next page in the manual.
Ive never read about any of them using a viscosity sensor.
Just change my oil over the weekend and those screws are aluminum not plastic.![]()
Check out those 8 plastic lock screws to remove the fairing shroud to get to the oil drain screw.
That's great & good to know thanks! Hate those cheap plastic screws.Just change my oil over the weekend and those screws are aluminum not plastic.
Here it is from p479 in the manual:Ken, do you know how to reset the maintenance minder? I tried hold down the trip reset and power on together beyond 25 sec but still it won't reset. Thank you
Personally, I think that Honda is using the same criteria for an oil change on the Clarity as they do on all their other cars. Kind of like the HV range issue. The software isn't taking into account the difference between a standard gasoline powered car and a plug in hybrid. Just my opinion, though.
