neal adkins
This is, unfortunately, a widespread myth on EV forums. Here are some actual facts:
1. It's claimed that repeatedly charging a battery pack to less than 100% and discharging it only partially, creates a "memory effect" which will reduce the amount of charge batteries hold, and that this can be fixed by first discharging the batteries to near-exhaustion and then charging them to 100%. The reality is that this applies only to NiCad batteries, and no modern EV uses NiCad batteries.
2. For cars with NiMH battery packs (not including the Clarity PHEV), some claim that the calibration of the battery pack's instruments (not the cells themselves -- just the calibration of the sensors) sometimes gets out of whack, and it's claimed that you need to fully discharge and then fully charge the pack in order to recalibrate the sensors. Some incorrectly claim that you can "recover" lost capacity -- and thus lost range -- in this manner. (Some call this a "memory effect", but technically that's incorrect, since it has a different cause than the actual memory effect in NiCad batteries.) Even if recalibrating the car's BMS (Battery Management System) will cause it to show a higher range than it previously did, that's still not actually adding to the car's EV range. It's only adding to what the car estimates as its EV range. And even in such a case, those who practice that technique say it should only be done once every 2-3 months, not once every few days.
3. There is no benefit at all to discharging-and-fully-charging for the Clarity PHEV, or other EVs using li-ion battery packs. All that will do is wear out your pack a bit faster.
For those who have even the slightest doubt that everything I've written here is 100% true, please read this discussion thread at the Tesla Motors Club forum. (It's true that the linked discussion is specifically for Tesla cars, which are BEVs, and the Clarity is a PHEV. But both types of cars use lithium-ion packs controlled by a BMS (Battery Management System) which constantly monitors the cells, and I think it's safe to believe that Honda's engineers were capable of competently designing a BMS.
Honda seems to imply cell balancing occurs at the top of the cycle and thus recommends charging to 100 percent before driving. That's what I recall reading in the manual. I think You have an excellent understanding of the issue. Thanks for your post Vicking79. I'm down in Southwest Arizona so I need a good plan for hot summer months. What I have been doing is charge to 100 percent. If I don't drive for several hours I just run the climate control remotely some and discharge to around 90 percent . Any advice would be appreciated.Cell balancing is vastly different than memory effect. Cells sometimes discharge at slightly different rates (as percent of SoC) due to differences in internal resistance, etc.
When you charge/discharge over many cycles they can get out of balance. Depending on when the car balances cells, usually after charging or "at the top" the car will charge to a certain voltage then bleed power from the high voltage cells, usually by shunting through a resistor to ground (creating heat) so they are all the same voltage.
This process usually only happens during the last phase of charging.
What happens over time is the car has a low voltage trigger for each cell, if any cell reaches min voltage the battery is dead. The SoC is based on current out of the pack, expected capacity and voltage of the pack.
If cell balancing gets very off it can lead to cells reaching their cutoff voltage early meaning a suddenly dead pack even though it is registering some charge.
Bolt EV had a recall for this, and not charging all the way on a regular basis could lead to the same. It is implementation specific though as balancing could occur if not fully charged. Don't know what Honda BMS does specifically.
