Attempted to search but could not find if topic was discussed already. Looking to improve the handling of my Clarity. Any options?
Get Michelin Pilot Sport 4S tiresThe simplest way to improve handling is to install high performance tires. The size of Clarity's tires 235/45/18 is compatible with even the highest performance summer tires. The OEM tires, although pretty much the best for green tires, emphasize range and mileage so they don't do as well for handling and braking. Replacing the OEM tires with high performance A/S tires (the kind they install on BMWs and Audis) will improve handling, braking, and likely bad weather performance. They will definitely make the car safer and more fun to drive. Someone in the forum who has done this said you will lose about 10% of range and Hv mileage though.
It would definitely decrease electric range and fuel economy somewhat. However it wouldn’t do so to “shitty” levels and definitely wouldn’t void any warranties other than the ones for the OEM tires.... Changing the tires would give you shitty energy and gas mileage might as well buy a different car at that point. It will also void out any warranty on the car, be careful.
