Tiralc
I'll add a few notes as I think of them, probably soon there will be other former and present Volt drivers who will add their comments and suggestions. Here are a few to start off.
If you were a VOLT "L" person, just go right to Clarity D, sport mode, and set four chevrons regen (after D, with four short tugs of the "-" selector paddle). If not equivalent, it's pretty similar to Volt L (maybe 85 to 90% of Volt L). (forget Volt sport mode, it's different in Clarity.) [BTW: This is not a good first mode for test drivers without one-pedal driving experience. Find a quiet road to practice first.]
But first, Volt/ELR drivers, DO NOT pull and hold either regen paddle expecting to engage regen like we do in the Volt or ELR! The Clarity regen paddles are only used to select the level of regen that you will be using.
Next, this is going to take just a little more effort for local - highway - local. Many of us started in the Volt with L local, and D highway. But, then we forgot to go to D highway, and eventually climbed into the Volt, pulled back to L, and that was that. If you wanted to save battery for the destination, you selected HOLD mode while still in L or D.
Now, you can get your L driving with sport, 4 regen. However, to get HOLD, once at highway speed (exact timing personal preference), change from sport to one short push of "HV mode". Now you hold the battery charge to what it was. At this point, you are effectively in VOLT D, hold mode. (yes, you can still play with the regen selector paddles for a little regen, but that's for another thread.)
Then at some point before or after your exit from the highway, simply go back to sport, 4 regen (four short pulls of the "-" left side regen paddle, like shifting gears).
Note, that you are in Clarity D the whole time. Eco, Sport, and HV are selectable modes of Clarity D.
I think it will become first nature with some practice.
The Clarity controls will be relatively easy to understand for most EV/PHEV/Hybrid technically inclined drivers, however, I suspect the Clarity regen selector paddles may be less clear for some. Also, I realized as I wrote this note why ICE vehicle operation is so relatively standardized by federal law ... (not saying we need that, just why there will be so many different ways that EV / PHEV controls are implemented)
