pictsidhe
The 80% rule predates Tesla. Early in the development of Lithium cells, it was found that staying away from the extremes of charge increased their cycle life. There has been considerable refinement since which reduces the damage from going to 0 or 100, but the effect is still there. Your battery will push your car further if you keep it between 30% and 80%.
Tool batteries are generally only charged to 4V/cell to increase life.
Saying that, anecdotal evidence is that the Mini battery holds up very well, however you charge it.
I have noticed there seems to be a delay in balancing, but I haven't dug into this.
My SOH has been floating around in the lower 90s. I'm at 45k miles. I've not been very religious about 30-80, though I do aim at that range if I won't need all the range. With the Mini's buffer, a displayed 20-80 should equate to 30-80 and maximise the miles you get from a battery. I'm planning to keep my SE until it dies, so I try not to abuse it too badly. Hopefully, by the time the battery has lost significant capacity, there will be a higher capacity retrofit option, as there now is for the i3. If I could find out exact cell dimensions, this could be investigated. An extra 10kWh would make the car perfect for me. SE cells start life at 97.2Ah. It is often confused with the 93Ah i3 battery. The i3 cells are made by a different company in a different country...
