I like looking at info an also seeing android settings. I can get into dealer mode but has anyone successfully got into engineering mode on a 2019 kona preferred ( 7 inch screen)?
dealer mode is simple, use the volume control on the steering wheel and the right button just below the radio -> car on go to setup-> version then set volume to 0 then set volume to 7 press right button then volume to 3,then press right button, then 1, then right button then it pops up with password 2400 worked for me for dealer mode. shows you radio info an that. but ive read elsewhere that you can get engineering mode from the same spot with a different code, has anyone tried it? i tried 2900 and 0428 with no luck
i tried doing the 5 taps and 1 on the other side on the same screen but couldnt get to it at all, and also tried the screensaver screen as well
