Dan Albrich
In 2022 my dealer asked me to change the transmission fluid at 37,500 miles. I agreed to do it. I never saw the "3" in maintenance minder. "3" is what you see when transmission fluid change is due. I am a little frustrated as I think they had me do it early and now that's delayed or interfered with the normal "3" for maintenance minder. I have not ever seen it.
I'm at 80K miles now. Just watched it flip to 80K on the dot. Had it in to the dealer for an oil change (had the A1 maintenance minder). They suggested I do the transmission fluid. I declined because my dealer seems to list tons of optional maintenance like its required. Also they implied I'd never done it, until I reminded them of the change at 37500 miles, then acted like "oh, now I see it."
From looking online, I saw youtube video on do it yourself, and the person doing it was at 90K miles their first change out. Another source said every 60-100K miles. Perhaps related Clarity doesn't have a normal transmission (they call it ecvt) but it only engages "engine" drive mode under specific conditions. i.e. so many miles per hour, relative flat grade etc.
So the questions:
- Ideally should one just always wait for the maintenance minder and just do this when the "3" shows up?
- Since I may of done my first one "early" don't really know which increment next one should be. I'm thinking maybe between the next 10-20K miles. Or is it smart enough to just throw the 3 when it needs it next?
For oil changes since maybe 90% of my driving is electric, even when they do them my oil looks clean. All I know is Clarity doesn't always follow generic maintenance timing.
-Dan
PS: The car is driving fine, doesn't make any odd noises and has never appeared to have an issue "shifting." In case curious, I have a 120K / 8 yr Hondcare warranty. I've been doing all required (maintenance minder) maintenance at the same dealer (and its where I bought the car). It seemed simpler to have all the records there in case I encounter a warranty issue. When my HondaCare is expired, I'll likely only use the dealer if necessary. They have not been honest with me on a few occasions.
So the questions:
-Dan
