Dave Fundakowski
Yeah, I know turn around don't let your range go down..
A few months ago I was stuck on the other side of town during and after a couple of good size downpours and drove through some 4-in water. My range, which used to be about 300 and or so miles, is now only about 250 on a full charge.
As an engineer this has my mind churning about all kinds of problems that could have been created in my EV from Deep water. The service guy at the dealer said not to worry about it: 'he frequently has to reset mileage range calculators on cars and that it's no big deal'.
A few questions come to mind: has anyone else experienced something similar?
If so, tell me what you know..
My mind goes to a couple of things: one I actually got water into my high voltage battery pack and it has either corroded some connections or damaged cells themselves and isn't allowing the battery to charge fully. Which brings up another interesting question: exactly how does an EV know how charged it is? Is there a charge accumulator or effectively a current integrator? Or, does it just look at battery voltage and know that when it's at its full Voltage it's fully charged in that should give you the range specified? This seems like a likely cause if I charged it when it was wet and that caused some cell connections to corrode and only fraction of my cells are being charged, While others do not have a connection to the charging source, from corroded connections. That seems fairly likely to me; but the dealer says 'no there's no way for water to get in there'. But, if it has connections going into the battery pack for heating and cooling as well as charging and operation, there are certainly opportunities for leaks.
The other possibility is that I got water in some of my 12 volt circuitry and that has caused some leakage paths that is making my high voltage battery have to charge my 12 volt battery more frequently, thus decreasing my range?
Any inputs would be welcome. Right now, I'm just waiting for the summer heat to get here when I can be relatively assured that anything that was once wet in my car is now completely dried out, as routine temperatures are 100+ here
