polyphonic
We had a momentary notification today "battery discharging while stopped"
Time for new 12v? Seems a little early for a 2021 car, but IDK.
Might not be anything wrong with the 12 V battery. I was getting that error frequently at one point and it turned out the buttons on my key fob were being pressed while in my pocket when I was sitting in my office, keeping the SE active. I now take the key out of my pocket and haven't had the issue.We had a momentary notification today "battery discharging while stopped"
I've had that intermittently since the car was new. Once while the dealer had it, after which they stopped telling me I must have been doing something wrong. If it happens while plugged in for a timed charge, the car won't charge. I fitted a 12V battery logger in December and am awaiting the next incident. Viewing logs, it does appear that the car will often have fits of waking frequently when it shouldn't.We had a momentary notification today "battery discharging while stopped"
Mine will do it with the fob in a cupboard or just completely out of range.Might not be anything wrong with the 12 V battery. I was getting that error frequently at one point and it turned out the buttons on my key fob were being pressed while in my pocket when I was sitting in my office, keeping the SE active. I now take the key out of my pocket and haven't had the issue.
**** happens.My IBS is smart enough to sneak up on me at the most inopportune moments possible.![]()
Having owned multiple MINIs and needing to replace a few batteries, my experience is they use AGM batteries and they have to be "paired" with the vehicle. I believe there are issues that can come up (errors, etc.) if one doesn't do the pairing process.
I sold BMW I3 with 7 years old battery which was only 20 Ah as I was monitoring that battery for last few month was always 14.4 volts in a morning.SE 12V battery is 50 Ah compared to I3 is a monster size as both cars have the same equipment. 12 V battery is automatically charged through DC to DC system from HV battery if car is plug for charging or not as long the system operate correctly and 12 V battery is not a lemon I will not be worry about it as the oldest SE is about 5 years old I doubt if anybody replaced yet. I belive at dealer OM AGM - 12 V battery is about $450maybe i missed it but did anyone answer the OPs question. Has anyone replaced the 12v battery on there se
They do exist and I considering switching to one, but price was too high. Certainly lighter than a lead-acid battery, but since the SE uses a relatively small AGM battery maybe the weight difference wouldn't be significant. What's the downside? Maybe the way the SE keeps the 12 V battery charged to 100% would be detrimental?be happy you don’t have to worry about 12v lithium ion batteries yet….
The mini cooper SE uses a 50 Ah AGM Absorbed Glass Mat battery for its low-voltage system 12 v. For starting and powering accessories as HVB pack is a lithium-ion battery just to straight this opinion.If you get the battery discharge warning message frequently you can try to do a deep slow charge of it. Or replace it. At the shop we try the slow charger method first.
As I’m using AGM 12v batteries for many years on gas cars they never fail in 5 years as a precaution I always change them after 5 years if I keep car that long ? but as I said before i3 20 Ah survive 7 years in SE 50 AH should last longer as powering the same equipment of SE with weight of 40 lbs to 20Ah 20 lbs as we talking about lighter lithium- ion 12 v. Batteries and more expensive too I wish to loose 25 lbs on my body weight to compensate heavier AGM B to lithium-ion . Price is very important . Why SE have 12 v battery on driver side do not try balance a weight of a car as we drive that car mostly as a single occupants should be on passenger sideThey do exist and I considering switching to one, but price was too high. Certainly lighter than a lead-acid battery, but since the SE uses a relatively small AGM battery maybe the weight difference wouldn't be significant. What's the downside? Maybe the way the SE keeps the 12 V battery charged to 100% would be detrimental?
A lithium-ion upgrade for your car, but not the one you’re expecting
Answer from the country where our SEs were made: "It was balanced until you made us move the driver to the wrong side."Why SE have 12 v battery on driver side do not try balance a weight of a car as we drive that car mostly as a single occupants should be on passenger side
