Happy to report works quite well after trying this feature out even though the roads are wet.
Energy consumption menu- regen limited to ~ 7kW easy braking, ~15kW heavy braking...a reduction from ~ 30 kW and 60kW when feature disabled.
Saves switching to neutral when required as in my previous model.
Press and hold the AUTO HOLD button for over 3 seconds.
- Brake Disc Cleaning starts operating when the message ‘Brake disc cleaning’ is displayed on the instrument cluster.
- Regenerative braking is restrained while the brake is depressed approximately 10 times while driving (it may differ depending on driving conditions). It helps reduce noise and rust.
- The Brake Disc Cleaning function will turn off automatically when the operation is completed. It can also be turned off before the operation is completed by turning off the vehicle or pressing the AUTO HOLD button for over 3 seconds.
