Those sub-$1000 solar generators typically have about 1000 watts of capacity, or less. Translation: It may power a 100w load for 8-10 hours. If it only charges at 10A, it will take 8-10 hours to fully recharge once depleted. In a hurricane, with 85mph winds and a torrential downpour it may take a bit longer to charge the batteries. That’s if the panels aren’t blown away.
Those things look impressive in the sales pitch videos. Once called to task, it’s a different story.
Why not buy a $200-300, 1000 watt inverter and connect it to the 12V in the Clarity? That will run 800-1000 watts every hour for at least 12 hours before the engine fires up. Then you have 7 gallons of gas that’s easy to replace. You have access to a 17kWh battery. Why would you spend $1000 on a 1kWh battery that’s packaged with a small inverter/charger and a few outlets? On top of that, you’ll pay a premium for some inferior portable solar panels.
Hi Landshark. I’ve seen several of your posts on these forums. Happy to see you comment on my response too.
For starters, my plan with using the Clarity for backup is solely for after a hurricane has past. I have an attached garage that will be secured from a storm. But I’m not a fan of running a hybrid car indoors since this PHEV still has a gas engine. Obviously you don’t want that turning on inside a garage.
But for other people, especially in Northern states where bad winter weather hits, it can still be used for temporary backup power.
My use for backup power is just to maintain my refrigerator and that’s not a device that is constantly running. It’s also a modern refrigerator which sucks like 150 watts when on. So it’s quite minimal. Yes I can get 15 hours or so from my Bluetti solar generator for just my fridge without plugging that into any solar.
Regarding the 10amps, yes that’s the max it will accept. I know it would take 12 hours to charge to full from a 12v outlet.
The point I was trying to make is that if someone had a solar generator already, the Clarity PHEV can serve as a generator without the need to buy a separate 1000 watt inverter, or extra cables. It’s not ideal by any means but in an emergency, it will work. It’s a good option for night time use, considering solar is not an option.
Oh and regarding solar panels, I don’t have any on my roof, but I have a few portable panels which will be fine to use once the storm is gone.
