Will these wheels fit?
I was looking at the following wheels and was curious if they might fit?
Classic BBS RX503 8Jx17H2 ET35 Alloy Rims
17x8
35mm offset
57.1mm center bore
5x112 PCD
Looking to sell my Coronas as I am not a fan of the styling.
Thanks for your help!
17x8
35mm offset
57.1mm center bore
5x112 PCD
I can't answer your question, but might be interested in your Power Spoke wheels (depending on condition/cost/convenience of acquisition).
I’m on 2022 SE with Hankooks 195/55/16” and my choice for all weather tires is Nokian WRG-5 Remedy and only available size is 205/55/16” Can some member on Forum tell me is wearing that size on SE 205/55/16 without any issues IMG_1682.webp bc no tire shop wants give me an answer if they fit for SE .That Nokian is low resistance rolling tire design for EV and have snow flake on it for all weather traction with 60000 miles warranty.why I want that tire bc on my Subaru I installed WRG-4 Nokian older version and I love it rain snow heat after 15000 miles no wear at all and handling is great . Also bc I will be driving up north from NewYork through winter I need that tires which I can have more benefits not just strictly Nokian Hakkapeliitta winter tires .My trip is 70 miles each way but I can charge at home there or Charge Point public 300 yards from house .
17x8
35mm offset
57.1mm center bore
5x112 PCD
Pretty sure the center bore should be 66.6mm to fit (or larger than that with hub rings).
I’m on 2022 SE with Hankooks 195/55/16” and my choice for all weather tires is Nokian WRG-5 Remedy and only available size is 205/55/16” Can some member on Forum tell me is wearing that size on SE 205/55/16 without any issues View attachment 23315 bc no tire shop wants give me an answer if they fit for SE .That Nokian is low resistance rolling tire design for EV and have snow flake on it for all weather traction with 60000 miles warranty.why I want that tire bc on my Subaru I installed WRG-4 Nokian older version and I love it rain snow heat after 15000 miles no wear at all and handling is great . Also bc I will be driving up north from NewYork through winter I need that tires which I can have more benefits not just strictly Nokian Hakkapeliitta winter tires .My trip is 70 miles each way but I can charge at home there or Charge Point public 300 yards from house .
I'm no expert, but 205 is the standard width for 17", and aren't some folks even running 215s without spacers? My guess is that they would work unless there is >1 cm difference in offset between 16" and 17" wheels.
8Js would likely be better shod with 225s, though. Unless you like the stretched look and don't mind being mocked by other Motorers.
I’m still looking for answers I need someone who put 205 /55/16 on factory 195/55/16 as I’m sure this can works need help who runs those without issues?
Yes, they will fit.
Yes, they will fit.
Just to make sure you have them on a car or is just a logical statement 205/55/16? Fit? I really appreciate your answer as yes they fit or is just bolt statement ! You see as I buy them and install I can’t return if they not work as $165 a tire
@Rexsio - I recommend getting a set of 10mm spacers (or thicker) to be certain. The stock wheels are inset enough that the inner sides of the stock tires are very close to the strut. Any aftermarket tire that is wider may rub. I have run some aftermarket tires on both 16" and 17" stock wheels on my SE, and even though they were the same size as OEM, they had a thicker rim protection bead that made them sit much closer to the strut than I was comfortable with.
My winter tires are 215/45/17 and I've had no issues. Seems hard to believe that narrower tires would rub.
Go on to tire racks site. They list the specs of the wheels. Also check out the other mini forums. Wheel and tire swaps have been going on with F56 Minis since the first 2014s rolled off the assembly line.
I run 205/55r16 Blizzard ws90s on my se for winter on the stock revolites. No you won't need a spacer.
They are a VW fitment. If they are PFS wheels, the inserts can be swapped for 66.6mm ones and they will fit perfectly. If not, they'll need machining.
I really appreciate your answer as I was waiting for from any member to clear my Nokian WRG-205/55/16 instead of 195/55/16 Hankooks summer tires as in New York I don’t need winter tires was my best choice to switch to all weather as I have them on Subaru and I love Nokians all weather tires as I have 4 rims 16” Revolte to switch as I have 8 Hankooks summer tires as I bought on crags list for $400 and for colder weather I get new Nokians all weather bellow 40’ F temperature.As you running Blizzaks 205/55/16 on 16” rims I’m very happy with an answer as everyone in tire shop not recommended morons !
Ordered those today 205/55 16 Nokian WRG-5 Remedy for $133,99 free shipping and I’m going to follow how they perform as they should be low resistance tires design for EW’s
I bought a set of wr-g4s 195/55-16s in late '22. The Nokians have a hard to measure efficiency loss. I believe that they are the lowest rolling resistance snow capable tyres. They are great in sub zero weather. Warm wet weather they are a little bit so-so. They are quite tolerant of 90-100F NC summers, but do appear to wear a bit quicker then.
I'd happily use them as all year commuter tyres in NY. I ran the euro version nokians all year back in the UK. I'm pretty sure that you will like them.
I've just splashed out on a set of extreme contact sport02s in 205/45-16. I have a probably wet event this weekend and my Nankangs are down to the wear bars... The Contis replaced worn out RT660s on my BBS RG-F wheels. I have not been able to find 205/50-15s Contis since spring. Supposedly on back order... Full throttle in the rain on the way back and power was only being limited to about 90% :D They should get better with a few miles on them. The Contis will be my autocross travelling and wet event tyres. The last time I drove in the rain on 200TWs, I was spinning the front wheels in cruise on the interstate :eek: . If the efficiency hit isn't too great, I may also daily the Contis. My factory Kooks have maybe 1/3 life left.
As I have on my factory Hooks 15000 miles and second set buy out 3000 miles with rims I don’t see much wear after 15000miles but as I’m. Traveling in winter up to CT from N.Y. as weather get cooler I need better tires as Nokian all weather WRG-5 Remedy
