It's shame we don't have a battery pre-heat option, presumably an easy software addition. But if it's any consolation, I’ve read of two incidents where the battery heater internal fuse melted. In the one case that caused a loss of HV isolation triggering the dreaded 'check electrical system' warning.… I do wish it had come with the battery heater, as charging a
cold pack is no fun.
That would be the GRU and or motor, definitely have it investigated with this TSB in hand. Fortunately, your car manufacture date is within the specified period to 1/19/21.start sounds like a wheel you spin with spikes on a country fair
The earlier, the better, as replacement parts may take some time to arrive.![]()
Actually I am taking her in for 60,000km service tomorrow. I already told them to check it out. It is very faint, but definitely a new sound. You really have to listen to it while driving on new pavement or the road/tire noise will mask it pretty well. I don't hope too for much, but at least the issue will be on record.
Just was wondering what other people's Kona's mileage are at and if they are seeing issues with them. Might help to track down when certain issues pop up or when to look for them. We just got our Kona the end of September, so we don't have many miles, but my wife will be putting approx 3000/month on it so it'll probably hit higher mileage than most other Kona's.
Current Mileage: 2400 miles
No issues so far.
** 1 year update **
1 year, 18,510 US miles on the clock.
the only problems I’ve encountered are stated above.
Keep on keeping on.
just another update to a ridiculously old thread.
2 years deep now with the 2022 Kona Limited, bought brand new. no issues at all to report.
no obvious signs of battery deg and 46,000 miles on the clock.
however,
I did notice about a 10 mile drop in battery performance on my 65 mile commute when I put the Blizzak Winter tires on.
I leave this on year round and don't swap wheel/tire sets. I over-all liked these tires for the winter but I do believe their performance is over stated. moving forward, I'll just be using all season tires once I burn these off. most likely the Altimax General R45 tires. I have 4 other cars that I've put those on and they perform year round fantastically!
This past Sunday, I took my longest single-charge trip in the 3+ years I've had my Kona - 223 miles round-trip (~375 km). This was a good time to assess the new Hankook tires. To me, the ride was much better and road noise much less noticeable vs the original Nexen tires and this was a direct comparison because part of the trip was on the same ~40-mile stretch of freeway I was using for my work commute.
The 2020-2024 MINI Cooper SE is not very aerodynamic, and it has a tiny 32.6 kWh battery. Understandably, MINI wanted to maximize the range of this car without compromising the brand's reputation for excellent handling. Somehow, MINI found tires that balanced these contradictory requirements wonderfully.I think "low-rolling-resistance" tires are gimmicky. On a test harness under controlled ideal conditions you might notice something, but in the real world just put reasonable tires and I don't think you'll notice. I put some lower end grippy Lexani UHP's on mine, I live in AZ these are 40K warm weather tires. Better ride, better handling, just plain better driving experience, and I didn't notice squat on the range. Would you really notice a 5 mile improvement with all the other variables that affect range? Driving from here up to the high country I made it to the charging station with roughly the same leftover range as always. I'd rather not squeal tires turning a corner or taking off a bit too briskly, than get some mythical 5ish extra miles of range.
Any sense of whether the tires impacted your range and energy use?
