Apologies if this has been discussed, but noticed in the UK that the street-side chargers have no cable. The style most frequently seen was Podpoint Pedestals with a CCS female connector, requiring the cable to be supplied by the user. Anecdotally, it seems the least reliable component of the typical public charger is the cable (or the cable's connector). If the user is required to bring their own cable:
1) The quality/reliability of that component is shifted to be the user's responsibility, and the user will be incentivized to keep it in good working order.
2) The EVSE is streamlined with no loose cable/connector to be damaged.
Is there a technical or governing body standards reason that double-ended cables are not employed in U.S. EVSE design? This would appear to be a simple solution to greatly improve the reliability of public charging stations with the added benefit of removing the idle cable as a tripping hazard.
