the current SE is already 300 lbs more than the ICE version
How can we be sure German SEs weigh the same as US SEs? I tried weighing my US-spec SE at a truck-stop, but I don't know how accurate the CAT scales are.I have always been curious about how much the current SE weighs, so this report caught my eye:
https://www-auto--motor--und--sport...ni-cooper-s-gegen-cooper-se/technische-daten/
According to it, the actual curb weight is (was) 1386 kg (3056 lbs), versus 1272 kg (2805 lbs) for the ICE version. The weight penalty is therefore 114 kg, or 251 lbs.
I had not considered that, but presumably any additional safety requirements leading to additional weight would apply equally to the EV and ICE versions?How can we be sure German SEs weigh the same as US SEs? I tried weighing my US-spec SE at a truck-stop, but I don't know how accurate the CAT scales are.
I believe I got out of the car and off the scale before the operator pushed the weigh button, so the actual weight it registered was the "gross" of 3,100 lbs. I also believe their scales round up to the next 100 lbs, to give truckers a small margin of safety for when they get weighed later at an official state weigh-station.
PS. In 2000, I tried the same scale with my (reported) 1,850-lb Honda Insight. The scale operator told me I needed to pull all 4 wheels onto the scale (even though I already had). He wasn't used to weighing such lightweight vehicles. I don't remember how much it registered 25 years ago.
Also isn't there a significant weight increase with the moonroof, like 30 pounds or more?How can we be sure German SEs weigh the same as US SEs?
Put batteries in behind a sits as 2persons car a rear seats in Mini are useless do a survey if people will buy I’m the first buying from 32.64 KwH to 65 KWh as new design as a two seater
When you start seeing better replacement batteries for EVs sold in greater numbers than the MINI, you can start hoping the replacement battery vendors will take note of the F56 MINI Cooper SE. Being the most agile EV on the market, it is the EV that would benefit the most from a high-density battery that would either a) extend the range or b) reduce the weight of (choose b for maximum fun--you're already used to the SE's paltry range).I have used my rear seats to house people on a few occasions and they've been fine - mind you only one >6 footer in the family and wife is 5'2. One instance was my foray to Portsmouth, NH, about 80min or so of driving. So I don't want to lose the rear seats.
What I want to see is improved denser battery tech. Over at Jalopnik Mr Golson gushes at the highly affordable electric Mercedes Benz G-wagon coming soon. But there's mention in the rather long article about "silicon anode" batteries with a 40% boost in density. That means we could get almost 41kW useable in our cherished SEs. Maybe other tech will improve on this too. I just have to start saving now because I'm not expecting a new battery to be inexpensive.
Which brings up the question. How many F56 SEs did MINI build and sell worldwide? What is the market for a new improved battery and who might make one?
cheers
MacMini34
200k SEs is an impressive number for a niche carNot a lot, at least in the big scheme of things.
Niche brand, only a 5 year model run (2020-2024 here in the US), and although the SE rose to become MINI's biggest seller, it was only one of multiple offerings.
ETA: 34,851 in 2021:
https://www.press.bmwgroup.com/glob...rand-sales-up-3-3-percent-in-2021?language=en
The above article also states that is a 98.2% increase over 2020, which means that 17,584 were sold the first year.
However, overall MINI sales flattened out after that year:
https://www.statista.com/statistics/267245/worldwide-sales-volume-of-mini-automobiles-since-2006/
So, while the SE has been popular, I'm guessing maybe 200,000 total units worldwide over 5 years?
By comparison, Ford sold approximately 750,000 F-150s in 2023 alone...
