Arctiic
So I've really gone and screwed myself over this time. I had a minor accident and had taken my Clarity in to a body shop for some minor cosmetic repairs. Unfortunately, they apparently (at some point in the repair process) disconnected the battery long enough to trigger the infotainment's anti-theft power loss state. Even more unfortunately, my infotainment center — previously damaged in an unrelated incident — does not have a working touch digitizer, meaning my on-screen touch buttons are not functional, which made it exceedingly difficult to find a way to bypass the anti-theft screen, as the only way to do so was to use the non-functioning Audio power key. And lastly, and most unfortunately, in my quest to find a method to programmatically send the equivalent
, I unwittingly thought to wipe the unit's
partition in the hopes that it would reset the anti-theft feature's active state; however, not only did it fail to do so, I inadvertantly wiped my network configuration off the headunit...which also meant losing my wireless ADB authorization. And without access to the touch screen and nor ADB to send any additional inputs, I've basically gone and tossed out my only method of accessing the headunit at all now. I've done derped myself good!
So I'm now back to sqare one (minus one). Any ideas what I should do? Besides biting the bullet and replacing the head unit altogether, that is? I'm already subscribed to most of the local yards so as soon as a Clarity gets junked around here, I'll jump on its carcass. Until then, I'm considering an aftermarket unit or something, but not sure if there'll be any unanticipated problems with that?
Approaching from the other angle, is there perhaps any way I can still bypass the anti-theft mode? I had pretty much scoured and read through all of the unit's .kl / input device / keymaps / etc file contents and tried all of the keyevent codes I was able to find. The problem was I wasn't able to get it to work in deactivating the anti-theft mode, whether because the
key event was some other non-standard input that differed from
, or because I was unable to successfully emulate a longpress
correctly for the system to accept it (and being pre-Kitkat, the
function does not yet include the
argument.
Side notes: interestingly enough, I've found several system activities are able to bypass the anti-theft block and supercede focus on the screen. These include, but likely aren't limited to: the climate control module UI, the lane-watch module camera UI, and the contacts application UI (I can't recall if this was invoked by the standard
or if there was a custom keyevent code off the top of my head). Unfortunately, it seems the former bypass method of accessing the system settings UI by first activating these screens appear to be patched out now (except for the Contacts UI as I did not think to test that at the time, and now no longer have the capability to do so).
Code:
keycode
Code:
sendevent
Code:
data
Code:
power
Code:
keyevent 26
Code:
sendevent
Code:
input
Code:
--longpress
Code:
keyevent 207
