KentuckyKen
Service Bulletin is SB 18-069
Dealer gets update from Honda and installs with a thumb drive.
Thanks, I never realized that works with the 'Low Fuel' warning too. I know I use it often for other alerts like 'low tire pressure' and 'service required'. I don't know why I didn't think of trying that for the low fuel warning.If you it the "i" button on the steering wheel it takes you back to the ev/hv range screen, or whatever screen you had visible before.
Did you notice what it was after update but before adding gas?Just got my HV range fixed today then filled up the tank. This is what it is showing on a full tank.
I had about 4.3 gallons in the tank and it was showing HV 263, if I remember correctly
Well that shoots down the 357 default theory.
You’ll know it needs the update the first time you fill up and the HV range jumps dramatically, but only if you mix in a lot of EV with your HV miles. Only with a lot of recent HV miles will it remain low without the update.All -
Thanks to everyone that has contributed to this Forum - it was very helpful with my lease decision.
Just came home with a new Clarity Touring and asked the dealer before I picked it up to apply this SB update. The Service Manager told me they checked my VIN number - which is close to 11000 - and it did not call for the update. The dealer took delivery in early June and I purposely asked for a later build Clarity, hoping some of the early bugs have been worked with increased production.
Ultimately I told the dealer I will drive the car for a few weeks and check back if the HV range continues to be higher then "357" (it showed "380" when I picked it up tonight with a full tank of gas!).
On a related note, I had the Clarity in "Economy" mode and the ICE engine did not turn on in my short drive home from the dealer - which included a drive up a 500 ft 1/2 mile hill.
Keep the faith. It should adjust as you add more gas to the tank.Did my update. Went from 1010 miles down to 397. I still do not think I could go 397 miles on a full charge and tank. Honda only advertises 360 miles range...right? Anyway....its better to say the least.
Just got the fix done in Canada. It isn't official yet but it's in their system.
Sent from my Pixel 2 XL using Inside EVs mobile app
My VIN ends in 9783 and I need the update.The Service Manager told me they checked my VIN number - which is close to 11000 - and it did not call for the update.
