Puppethead
MINI UK site lists J01 range as "182–249 miles range (WLTP)". That's much higher than the Abarth 500e range of 100-164 miles (I would assume also WLTP since it's a European figure). I'd say that might be worth an extra 300 lbs (equivalent of a passenger or two) if the handling is on par with the SE.It sounds like the 500e Abarth should have about the same speed and range as the J01 E model, while being ~300lb lighter.
