Mowcowbell
Thanks KentuckyKen, I'll cancel my Amazon order for the F106N and order the F106SX directly from Fumoto instead. It's $5 cheaper directly from Fumoto compared to Amazon.
Part of this may depend on how much you drive. We don't drive enough to warrant oil changes more often than the minimum once per year. I agree that there is no obvious way to avoid a 'mess' when changing the filter, so the valve doesn't really add much to the equation. If you had to change the oil twice a year (and maybe you decide to only change the filter every other time), it may be worth it. Also, although this is maybe more paranoia than reality, the valve does add extra interfaces that could result in potential leaks over time.I feel like I'd still need to keep the oil pan for that and if I'm keeping the pan I might as well forgo the Fumoto
I feel like I'd still need to keep the oil pan for that and if I'm keeping the pan I might as well forgo the Fumoto. What do you guys do?
