Jim In Tucson
Thanks everyone, this was a most informative thread. I just ordered both the better bracket and the tabless frame.
The first thing I did when I took delivery was to remove the skeuomorphic hood scoop, but I didn't replace it with anything. You didn't replace the license-plate holder, you just screwed your plate directly to the hatch? Did you remove your license-plate holder to add lightness? It seems that would make a stripped license-plate screw even more problematic.The first thing I do when I took delivery was to remove license plate holder.
Maybe the OP would pay you for your pristine, never-used license-plate holder.
So I tightened the screw a little too much and stripped out the very soft plastic of the rear license plate holder.
I thought op reported a stripped holder and not the screw so I am not sure what your "that would make a stripped license-plate screw even more problematic." comment is referencing.
I meant that it's easier to replace the cheap holder than the expensive hatch, so if a car detailer was working on your MINI and removed the license plate, it would cause a big problem if he stripped one of the holes you made for the license-plate screws. [Note: I brought an imaginary car-detailer into my scenario because I know you wouldn't accidently enlarge the hole.]
See post #14. Like many others here, I replaced mine with the $11 version from Amazon, and it is 10 times better than the stock one. I also put on a silicone “frame” which I think looks better overall than just the plate, while reducing vibration.The license plate holder is just a piece of plastic frame that goes on top of the license plate which can be replaced easily, as you can buy all different types of them at auto parts store as well as online stores. So why would the hatch of the car be involved?
I guess not. I think of a license-plate frame as the piece that goes on top of the plate, which is attached to the holder.
It's good that BMW and MINI use the same mounting for their rear license-plate holders. I was amazed to see more than 800 people bought this one on Amazon in the last month:See post #14. Like many others here, I replaced mine with the $11 version from Amazon, and it is 10 times better than the stock one. I also put on a silicone “frame” which I think looks better overall than just the plate, while reducing vibration.
So I tightened the screw a little too much and stripped out the very soft plastic of the rear license plate holder. Actually, I didn’t really torque it very much, but that plastic is soft and I guess it didn’t take much.
Anyone have any suggestions on what I can do so my license plate doesn’t fall off? There really should be a better way to attach the plate, especially in CA where I have to take the plate off every year to put on the new registration sticker. I’m not sure that plastic would have held up even I were careful.
For those in California dealing with yearly sticker changes, a license plate frame with an easier removal system might be worth considering. On another note, if this is a used car, checking its VIN history with a tool like FaxVin https://www.faxvin.com/vin-check/locator can uncover any prior damages that might explain the weaker materials in the holder. Good luck with your fix!
Is there a way to put some kind of threaded insert or something? I’d like to try and get a more permanent solution and I don’t want to lose my plate.
