Thank you and Yes they are! Was on the fence. Glad I went with 18s.
Awesome, are they 18x8? Do you mind sharing the tire size and setup you went with and offset? Also curious how range was affected by the 18’s?
45mm offset, everything else should be in the photo. Let me know if that works!
…I’ll be in my bunk.![]()
But do we have any say over which tires we get? My salesperson won't respond to that question. I am scheduled now, but try if I can get anywhere....Good to know, I will check that out when time comes. Seems like Mini has a few choices of OEM tires between Goodyear, Hankook and Pirelli.
My SE Sept 23 build came with run flat and nitrogen fill.
One of the best parts of the R53.Wait. It’s not a Brazilian Chrysler?
Update for those who are still waiting for packages to arrive via Royal Mail from the UK: I got my roll of black vinyl on Thursday, exactly one month after ordering it. So international parcels are definitely getting through, albeit very slowly.At least now I know why the vinyl tape I ordered on the 9th and that was dispatched on the 11th still isn’t showing in Royal Mail’s online tracking…
https://www.bbc.co.uk/news/business-64291272
Nitrogen is a waste of money compared to dry air IMHO. Yeah, maybe you'll pick up 0.1s at the track, but spend your money elsewhere on the road.MINI dealers have no way to specify which tires come on the MINI Cooper SE.
For the first time, one US forum member reported his SE came with run-flat tires instead of the normal go-flat summer-performance tires. Perhaps MINI ran out of the go-flats and just stuck tires from an ICE MINI on his SE, but he hasn't responded to confirm his suspicion that his SE is the 1st in the US delvered from the factory with run-flats.
Is there a way to confirm a nitrogen fill from the factory? Assuming the dealer didn't empty and refill the tires, do you have to fill a balloon from the tire, and then somehow test if a candle can burn in the gas that you captured?
