Did your SE come with run flats?
I also have Pirelli run flats; I upgraded to P1’s shortly after I bought the SE.
I had look up what a tire mobility kit actually is.
Google says…
MINI factory Mobility Kit for those who motor without run-flat tires. Temporarily fixes small tire punctures long enough so you can reach proper care-givers.
Kit includes:
nylon case
puncture sealant
high-performance pump, gloves
user’s manual
adaptor valves for inflating all kinds of things that need to be inflated
Sealant is available separately if you had to use the sealant or if your sealant is expired.
Because you don't have the Power Spoke wheels, you don't need the little wheel-cover removal tool (a bent piece of stiff wire) that has its own little niche in the tire mobility kit of US Iconic SEs with those wheels. For countries that get run-flat tires instead of a tire mobility kit, does MINI just throw this tool in the glove box?Cool, thanks. As Google says we don’t need them because we have run flats. I guess because both, the tyre mobility kit and the run flats are temporary solutions until you get your tyre puncture fixed.
It just doesn't taste as good after the expiration date (or so I hear)I do not have run flats and this kit was included.
I hadn’t noted the bit that the sealant expires though, I should check on that.
The advantage of runflats is you can drive at least 50 miles (80 km) on a total flat, no need for a mobility kit. The idea is runflats enable you to get to a service location instead of trying to change a spare in a dangerous side-of-road situation.We have Pirelli run flat tyres, do we need to buy a tyre mobility kit? Do we need one?
It's a toss up for RFT range for added sidewall weight vs deformation. There should be more efficiency losses with RFT compared to non RFT, but I don't think it's significant.The advantage of runflats is you can drive at least 50 miles (80 km) on a total flat, no need for a mobility kit. The idea is runflats enable you to get to a service location instead of trying to change a spare in a dangerous side-of-road situation.
I liked having runflats on my ICE MINIs, but they probably sacrifice some range on the SE and might be somewhat noisier. I think New Zealand is the only country I've heard of that equips SEs with runflats.
If it wasn't significant, why is the SE the only MINI delivered (to the US) with go-flats?It's a toss up for RFT range for added sidewall weight vs deformation. There should be more efficiency losses with RFT compared to non RFT, but I don't think it's significant.
There were no fake ICE engine sounds (Active Sound) piped through the stereo system to mask the road noise.If it wasn't significant, why is the SE the only MINI delivered (to the US) with go-flats?
They are! I swapped my run flats on my previous Mini and was happier. My winter tires are run flats as I am not screwing with that when it's cold. I just swapped. They are soooo loud. Notice it more on the SE with the engine vs my F55SThey are noisier. This is the 1st time I am driving with run flats. And I guess the tyre mobility kit felt like a security blanket.
The last time I checked, Honda wasn't selling an exact-size replacement for the tire-sealant kit in our Clarity PHEV. Let us know what you learn about refreshing MINI's tire-goo.
Did you then carry a fix-it kit of some kind?I ditched the run flats on my ICE Cooper S within 5 months of owning it.
I have a plug kit with an air pump. The sealant is very very annoying to deal with if used. I also carry a jack and lug wrench out of a bmw e46.Did you then carry a fix-it kit of some kind?
