Hugh G. Rektion
Hi!
Due to frequent power outages, I am considering using an EV battery as a power source for my 3-phase 380v industrial equipment (CNC machine, screw-type air compressor, band saw). The reason I choosing that EV because of its output voltage, which perfectly fits my machines (380v,~ 60A)
But I am a complete amateur in EV and electrical things in general, and therefore I ask you for help on the following:
1. Am i right that in order to use the battery I need to connect the charging device, connect the cooling line which will run through chiller and then connect the phase wires from my machines to battery's output terminals?
2. Will the firmware block the battery's operation if it "finds out" that the battery is being used outside the car?
3. Will I need additional equipment to get the pure sine or the battery provides the pure sine by default?
Will be very apppreciate for any inputs!
