Wildeyed
I took my car in for the seasonal tire swap and requested annual brake maintenance (lube, clean, etc ) while the tires were off.
They didn't do the work because my rear brakes are worn down to 1mm and now rotors and pads require replacement.
I was not/am not happy. It seems to me that with only 47k on the odometer that kind of brake wear is nuts. On an EV it should be unheard of!
My Service Manager agreed that it's not normal but could offer no explanation. Has anyone else had similar premature wear? Am I correct that this is not what should be expected at 47k on an EV? Is there anything I should look for as a cause, any future proofing I can do to ensure this doesn't happen again...like, ever?! Thanks.
