pictsidhe
Interesting... I'll try to measure it again when it reaches 100%
My capacity regain didn't show until the pack had been been cycled after a float.
I believe that recurrent reports estimated range, not SOH. One of you is having a little more than the other.
The electrified app for Android can access SOH from the car.
I just got my car last week and the dealer told me that I should keep the level 2 charge speed at reduced to save the battery but that kind of defeats the purpose of level 2 because it makes it so slow. Is this true? Is it really saving my battery or is it just limiting the power just in case the electrical can’t handle it?
Which mine can we have overkill with 100 amp service to a 50 amp plug.
Yeah that was my exact thought when he said that! I was like this doesn’t make any sense but then again he has only sold about 20 SEs. I just wish they would be little less misleading if they don’t know what they are talking about. Thank you for the help!
There's also a lot of confusing information out there about charging to 80%, because that's how Tesla decided to do things and they created the modern EV market. Another factor is the SE's charge speed is so low (max 50 kW DC) that it doesn't stress batteries like other EVs might that can go over 100 kW.
MINI decided to keep things simple and have the car do all of the necessary battery protection automatically, so for the SE it's: Always Be Charging. I have over 47,000 miles on my SE and I always charge at max rate, am not seeing any range degradation. I don't know what my SOH is, but maybe I don't want to know at this point.
I have found that many (but not all!) sales people (of cars or otherwise) are reticent to say “I don’t know”. Instead, they either make up an answer and say it with confidence, or answer a different question from what was asked.
The best answer they could give is “I don’t know, but let me find out for you”. It is truly refreshing when I am told that.
The most important question: Is this the same value BMW/MINI uses to determine if you get a new battery?So, the battery remembers how many electrons it was able to store on day 1, then subtracts the number of electrons stored today, and calculates the percentage of current capacity?
As inaccurate as the GOM is, I’d be hesitant to believe anything the battery tried to tell me.
Is this SOH data coming from the SE, meaning BMW designed it. Or is the SOH data coming from a 3rd party?
A 50A outlet should be on a 50A breaker. A 100A breaker is not safe, legal or a good idea. Swap the breaker for a 50A one. Wiring needs to be either 6g or 8g, depending on how it is run and how warm an environment it will be in.While this tread is active I have a question in a similar vein. I just got my car last week and the dealer told me that I should keep the level 2 charge speed at reduced to save the battery but that kind of defeats the purpose of level 2 because it makes it so slow. Is this true? Is it really saving my battery or is it just limiting the power just in case the electrical can’t handle it? Which mine can we have overkill with 100 amp service to a 50 amp plug.
