gonfunko
Hi all,
Has anyone gotten the Check Electric Vehicle System/warning triangle on a 2019 Kona? I've seen the 2021/2022 threads, but my situation seems a bit different. Specifically:
* Mine is a 2019, which had its original battery replaced under the recall
* Everybody else with this claims it immobilized the car; I get it every time I start the car/it remains continuously illuminated, but it lets me drive it fine (which is good, considering it first appeared at the North Rim of the Grand Canyon)
* It seems to have limited AC charging to 80%; the UI still reflects 100%, but it was sitting at 80% and not actively charging this morning.
A few other notes:
* I'm not sure about DC charging; I charged up to 80% twice on fast chargers after it appeared, but I have my fast charge limit set to 80% anyway, and both charges were uneventful.
* I haven't tried disconnecting the 12V, since I didn't need to to drive the car and I figured it'd be better for it to be actively showing the warning when I bring it to the dealer (who I'll call tomorrow when they open)
* The warning appeared in the morning after charging to 100% on a 50A plug at an RV park via a Tesla Mobile Connector + TeslaTap. The prior day was about 500 miles starting from 100% with 3 fast charges, in ~100-112º weather for most of the way, so I do sort of get why it might be angry. OTOH, the car performed great/all those charges worked fine, and I'm now back home after another 500 miles.
* I ordinarily always AC charge to 80%. On road trips, which I do every 3-6 months or so, I'll DC charging to 80% or AC charging to 100%.
* I've had an ongoing issue with a Refill Inverter Coolant message appearing intermittently on start; the coolant is full, the first time I took it to the dealer they flushed the system, but it persisted. The second time they noted the 12V battery was dying and suspected that was confusing it, so they replaced that, which reduced the frequency of the message, but I have still gotten the message a few times since, including twice since the Check Electric Vehicle System message appeared.
* The specific code being thrown per my OBD reader is "P1AA6(00) Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested"
* The OBD reader also shows a B1285(77) code, which seems to be HVAC related. The AC certainly seems to be functioning normally though!
I suspect this is probably a see-what-the-dealer-says situation, but just wanted to see if anyone else has had a similar experience or has any suggestions in the meantime!
A few other notes:
