I m getting 50-51 this entire summer on my 08![]()
I meant '18. So I am off by a decadeVery clever of you to get 50-51 miles with your '08 when that was 10 years before the Clarity was introduced![]()
My recent high on my 4 year old 63,000 mile car. I can't cheat since I live in flat Florida. I just drive 35-50 most of the time. View attachment 18087
I dunno, so I won't attempt to correct your thinking !!But I may not be thinking about this correctly….I’m sure someone will tell me if so.
I'm not sure that the "HV" GOM is smart enough to account for all this, but maybe it is?
Yes, I have never gotten anything close to this under any condition I have experienced. I think the highest I can remember is perhaps 56-58. Currently I get 50 consistently (with the A/C always on) - 2018 with ~34K miles.So, I’ll end with congratulating again on the 70 number
I am somewhat surprised that your HV number is very moderate, at 287. You would think the two would tie together, since it is (almost) always electricity moving the car. The EV number suggests extreme efficiency, so it shouldn’t seem to matter whether the electrons came from an external charge or from gas running the on-board generator. But I may not be thinking about this correctly…
And with A/C set to minimum no less, impressive!
HV Range is gas range. EV range is electric range. Combine the two and Total range is 358. We can’t see the fuel gauge, but note that the gauge for HV Range is down a notch from full. A range of 287 miles on 7 gallons of gas equals 41mpg. Right on target.
I get 260-270 for HV in winter when I get 35/40 for EV, and in summer I get 310-320 for HV and 50-55 for EV. There is some loose correlation because the car can operate at some particular level of efficiency whether in EV or HV.
NO! Not that impressive. It shows Low but I keep the AC button itself switched off. I only use AC when on the highway, or when my wife is in the car. Windows down around town is fine for me.And with A/C set to minimum no less, impressive!
I am somewhat surprised that your HV number is very moderate, at 287. You would think the two would tie together, since it is (almost) always electricity moving the car. The EV number suggests extreme efficiency, so it shouldn’t seem to matter whether the electrons came from an external charge or from gas running the on-board generator. But I may not be thinking about this correctly….I’m sure someone will tell me if so. [emoji5]
The HV/EV estimates are very separate. I do all around town driving on EV with no AC. When I go on the highway its almost always longer distance that requires gas/HV, and at much higher/less efficient speed, and I use AC on the highway so the HV estimate is not impressive. Landshark you did a great job figuring most of this out from just the info on the display!And with A/C set to minimum no less, impressive!
