Some random thoughts that came to me while reading this thread:
The name of the hybrid drive system is iMMD. The new CR-V uses the fourth generation of iMMD. (1st=2014 Accord PHEV, 2nd=not mass produced, 3rd=2017+ hybrids). The
line of cars that use it is called e:HEV.
In Engine Drive, the ICE's rpm is 37*MPH in the Accord. At least similar, and probably the same in the Clarity. But I'm not sure. It is used only in low-power situations, when the car needs less than the power of the engine operating at its most efficient. That's 34 HP in the Accord, and probably about 25 HP for the Clarity.
High power requires Hybrid Drive. "Angry Bees" happens at when high power requires high rpm. That is, when running the ICE at that power level is far short of the needs of the car. The sound is due to high rpm, close to 6000 rpm.
Motors do not produce power, they convert electrical power to mechanical power. Their role in HEVs and BEVs is closer to the role of a conventional car's the transmission (which, at most speeds, converts high-rpm mechanical power to low-rpm mechanical power) than the engine.
The energy source
s in an iMMD system are gasoline and the battery. Power is extracted from them by the ICE and Power Control Unit (PCU), respectively. This is what a car's power rating should reflect. Despite what the marketing department puts on spec sheets ("Total system horsepower [is] measured by the peak, concurrent output of the two electric motors and gasoline engine"), there is nothing "concurrent" about the output of those three devices when the iMMD runs in Hybrid Drive. "Concurrent" means "operating in parallel," and those devices operate in series. Adding them when a Clarity is running at max power would come to almost 400 HP, and be meaningless since the motor-generators are just converting the power of another.
It is not "non-Insight" hybrids that are (were) rated at 212 HP combined. It was those that used the 181 HP traction motor. Because 181/0.85=212. The Insight used a 129 HP motor, and has a 151 HP "combined" rating because 129/0.85=151. The City/Jazz hybrid also uses that formula, but I don't have its specs handy.
The reason for this is that there is a rule of thumb, that the max power at the wheels of a conventional car is 85% of the power the ICE can produce. Yes, I know this is inaccurate -
here is a site that discusses it. All I'm saying is that it exists, and that Honda quite clear;ly uses this rule-of-thumb to back-estimate the power needed by the traction motor. The generator+battery are probably more capable, but this is saying no more will ever be used.
That was when there wasn't a standard for HEVs. Now apparently there is. The new CR-V is rated at only 204 HP, but that is actually a slight
increase in power, since the 212 HP Accord and CR-V would have been rated at 201 HP with this standard. I have no idea what the Clarity would get, but there is no longer a reason to expect it is the same.
Finally, I have seen mixed reports about the two-speed lock-up in the new CR-V. Some say it is for towing, and some say it is for lower speeds. I think I saw somewhere that it doubles the gear ratio, but I also don't have that handy. My point is that I don't know for sure if the Accord will get it.
