Looks good. What tool did you use to remove the plastic pieces? Is the bodyside moulding specific to the Clarity?
Yes. It is pre-painted. I ordered it online and my sons (both in 20s) put it on my and my father in law’s cars. You can also get mud guards and clear plastic paint protector for the top of bumper. There are also chrome accent pieces that go on the bottom of the doors.As far as I know the moulding is specific to the Clarity. A Honda dealer would be able to tell you for sure.
If you remove the wheel, from the back side you have access to the clips and they are very easy to remove. Also reduces the chances of breaking the clips on these very expensive pieces of plastic.I wrapped a screwdriver in cloth and popped every other clip out then pulled with my hands to remove the rest. You have to remove the lug nuts to get them off. I just put the lug nuts back on so I could drive.
I didn't realize the clips were separate, I was worried they were part of the cover and that if you broke one you'd be toast. Although it seems possible at least in theory to break the attachment point between the clip and the cover. Probably unlikely though.I had no problems removing the clips from the front. They took some pressure, but popped loose pretty easily. Those clips are not expensive.
I didn't even realize that the clips were accessible from the front until your post, although when I went out to look at mine I found that I could release the clips pretty easily by just by sticking my fingers through the opening on either side and pinching the clip, I didn't need a screwdriver. When the time comes I will probably release all of the clips rather than putting force on the remaining clips, which I think would place at least some stress on the clip attachment point. Again it will probably be fine, but after seeing the prices on the covers ($281 retail) I prefer to use caution. But good to know the covers can be easily removed without taking off the wheel.
Sort of funny but I went on eBay to see what used covers go for, as usual the prices are all over the place. There was a slightly scratched used one for sale for $60, the listing said HONDA CLARITY OEM WHEEL COVER ONE BROKEN TAB. Looking at the pictures it appears that it's just one of the clips that are broken as I can only see one of the two prongs on that clip. I sent a message to the seller with the part number you gave and told them they can get a new clip pretty cheap.
Do you mean the clips are tough, or the attachment to the wheel cover? If the attachment breaks it costs $281 (retail) to replace compared to the clips at $3.08. I don't have a removed wheel cover in front of me to look at and see how the clip is attached to the cover, but I'm guessing the back of the plastic cover has some type of tabs or openings molded into it which hold onto the clips. If that part of the wheel cover breaks then the clip won't stay attached anymore. Although I suppose you could survive with one missing clip as long as it doesn't rattle. Maybe next time I take one of the covers off and look at how the clips are attached to the wheel cover all of my concerns will be allayed.I found them to be pretty tough. Nice idea letting the seller know.
Just because it doesn't break the first time doesn't mean that stress wasn't put on the plastic tab, and repeated stress can lead to eventual breakage of the tab, which is unfixable. And unlike the clip not replaceable since the tab is molded into the wheel cover. How many non-gentle removals would it take to eventually break a tab? I have no idea. Maybe they will never break. But in this case it seems easy to avoid the risk by releasing all of the clips, which seemed pretty easy by reaching through the opening with my fingers and pinching the clips. Then the cover comes off with no force required.You'd have to work pretty hard to break a clip. I was not at all gentle when pulling them loose and had no problems with breaking.
Am I the only forum member who purchased Honda's Clarity accessory wheels? I relegated the OEM wheels to winter use.
The accessory wheels were in the Clarity accessories catalog from day 1 and I liked their look. They don't include the internal sound-deadening baffles or the fancy plastic covers like the OEM wheels, but they cost about 25% as much as new OEM wheels when I bought them.Yes, I do think you are. I had no idea they were an option. Never seen them before.
