The SEs with Power Spoke wheels come with a little wire hook in the rear kit. You stick that hook into a hole in the extended center-cap and pull off the extended center-cap to reveal the wheel bolts.How does one remove a Power Spoke wheel?
Do you know about the special adapter required to balance a Power Spoke wheel? It simulates the weight of the off-center extended center cap while the wheel is on the tire-balancing machine.thanks still finding all of the features of my new SE
Here you go: https://www.ecstuning.com/b-genuine-mini-parts/adapter/83302471407/@insightman Is there a link to acquire the balancing tool? I wonder if it would be smart to have one in the boot just in case I need to go somewhere other than a dealer, or if enough time passes that dealers forget about them.
I keep it in my glovebox.
The "plug" outlines are plastic.Two questions related to power spoke wheels...
- Are the rectangular 'plug' outlines diamond cut and subject to corrosion?
- Is the yellow mini circle in the middle built into the cover piece, or is it removable? I'm wondering if it's possible to replace it with mini's self-leveling caps.
I drive with Power Spoke and seem to get almost 160 mi range (well over 5 kW/h). I also weighed them and they are very light, weighing 39.4 pounds with tires on.Looks aside, has anyone done any testing to determine if the Power Spoke wheels provide any aerodynamic (and therefore range) advantage?
Sound to me like English try to build and rediscover square wheel .That is not BMW design.Could be a joke on my side .The "plug" outlines are plastic.
The mini badge is built into the cover piece, which I learned the hard way.
I'm 99% sure the bit pointed at is plastic, but I'm more than 1,000 miles from my car so I can't check.The red arrow is the bit I'm interested in.
Based on that post the light gray part should be plastic to be consistent with the cover, the inner gray being the (aluminum) rim itself. Maybe the dark gray is a plastic cladding on top of the rim. What a time to be away from my SE.The white arrow points to plastc; red arrow points to aluminum.
I posted that link to illustrate that the wheel bolt holes are in the gray-painted aluminum center. There is clearly a break between the aluminum spokes and the four plastic fillers, but no break between the polished aluminum and the gray-painted aluminum.Based on that post the light gray part should be plastic to be consistent with the cover, the inner gray being the (aluminum) rim itself. Maybe the dark gray is a plastic cladding on top of the rim. What a time to be away from my SE.
But aluminum corrosion is a generally protective layer of aluminum oxide, so it's nothing to worry about.
My overall impression is that wheel aerodynamics have an almost immeasurable impact, which is contrary to common belief.
