The system will protect the battery by refusing to start if the battery is too cold, so I don't think you will hurt it by letting it sit unplugged. However your Canadian model's battery warmer won't work if you are not plugged in. The manual indicates that -30C battery temperature is the point where the car won't start, but even if it doesn't get that cold the manual suggests keeping it plugged in so that the using the battery warmer can maintain the temperature for better efficiency.I know battery doesn’t like cold. My question is if I know I’m not going to drive my car in a few days, do I have to plug it in under -20°C? Can I just plug in the night before I drive it? Does it harm my battery in any way?
Only Canadian models have the battery warmer. Presumably that was an American Honda Motor Company decision not a Honda Motor Company decision. Honda Canada is a different sales organization and that's why there are a few differences, like no power seats in Canada not even in the Touring modelIt depends on whether your car has a battery heater. This should be mandatory in areas with cold winters
I have read that lithium batteries won't be damaged by cold temperature, they are only damaged if they are operated in temperatures below a certain point. But the system prevents that, if it gets too cold it won't let you start the car or charge it or even use the battery warmer. The owners manual doesn't warn against leaving the car out in the cold in terms of harming the battery, it only mentions lower efficiency, or the possibility that the car won't start. Honda is on the hook for 8-10 years of battery warranty so presumably they would say something if it would harm the battery to let the car sit several days unplugged in sub-freezing weather.I won't profess to be an expert on this but if your battery is bricked it won't accept a charge until it warms up so there could be a delay until it's warmed enough to charge. I have no idea whether or not the cells can actually be damaged by being subjected to these temperatures. Perhaps some others will chime in on that.
You seem to be under the impression that the Clarity battery warmer can be powered by the HV battery, like it apparently can be in your Leaf. It can't. According to the owners manual the Clarity battery warmer only works when the car is plugged in. The SOC of the HV battery has no impact on whether the battery warmer runs or not, since the warmer is always powered by the grid.If your battery SOC drops below a certain amount (it's 30% with the Leaf) the battery warmer is turned off. So here's what I would do. Make a note of your SOC when the car is to be left for a few days. Check it each morning to make a note of any decline. This will give you a handle on how much charge you can expect to lose every 24 hours due to the battery warmer. You'll know whether or not you need to top up to keep it above 30% before the end of the idle period.
You could also use your car's built in charge timer to say give it 1/2 hour every 24 hours and just leave it plugged in. That way the battery warmer will operate off grid power instead of the battery. Then you can charge to whatever level you normally do the night before your next day's use.
