apu
With nearly 60,000km on the clock my time for my first coolant changes is coming soon so I decided to start a coolant change thread as there seems to be very little web info on the topic for the Kona EV. As usual I am hoping we can collectively help each other with information shared. I am hoping we can keep this post on topic in this thread as much as possible.
This is what I know right now:
There are 2 types of coolants green which seems relatively conventional and blue which is claimed to have low conductivity properties. I have not been able to find a aftermarket equivalent that meets Hyundai requirements for low conductivity. The use of an alternate non conductive coolant wouldn't be the end of the world but likely would void your warranty if you had a related claim and open yourself up to theoretical battery fire if coolant would leak into the battery compartment.
My dealer's parts department here in Canada has quoted me $115 per 2 liter Hyundai EV coolant jug(presumably its concentrated, but I am not 100% certain) A complete coolant flush requires 13 liters for a Kona EV with heat pump. So we are talking about at least $350 + taxes for just the coolant. I was rather shocked at the price so I didn't bother to ask about the labor cost but I would figure around 1.5 hours as this what they charge Hyundai for warranty related coolant changes.
The flush process is not difficult but time intensive. The process calls for a drain and complete flush with water and subsequent refill with new coolant. You need a scan tool that supports bidirectional control of the 2 electric water pumps. Outside of Hyundai's dealer level GDS tool Autel makes some tools that may provide this function. There may be more I am not sure. You need to put the 12V battery on external 12V supply during the process as the pumps can run in excess of 30 minutes.
Does anyone know what the Hyundai part number is for the blue coolant?
