David in TN
I rotate my tires at each Maintenance Minder suggestion.
1. Jack up the rear of the car and swap tires from side-to-side.
2. Jack up left side and swap front-to-rear.
3. Repeat on right side.
I remove lug nuts with a battery-powered impact wrench.
I install lug nuts by hand threading them on "at least" two full turns, then using a cheap battery-powered drill with a socket adapter, I tighten them with the drill (about 20 ft-lbs.)
After lowering the car, I torque all lug nuts to 80 ft-lbs.
NOW...
When rotating a while back, I had a lug nut on the right-rear get stuck. Then I had two that wouldn't tighten properly. After physically breaking them off (so I could replace them) and doing some examination, it appears that the studs themselves have "s t r e t c h e d" somehow. The next rotation, I experience the same with the left-rear.
I have now replaced all wheel studs and lug nuts on the rear of my Clarity (I'm about 77k miles.) There seems to not be any issues with the front ones... yet. I purchased nuts/studs at O'Reilly and Advance Auto, and they were the same part numbers at both places.
Replacing them is fairly easy if you can get the brake caliper bolts to come loose.
NOW...
