If the battery supports at least 4Q charging. To explain, Q is the capacity of the battery (eg 1Ah). You can discharge a battery a maximum rate without damaging it. Say that value was 5 - you can discharge the battery at 5A (5 * 1Ah - ignoring the 'h'). You charge at another rate. Most Li batteries like between 1 to 2 Q. This means, by definition, that you can charge between 1/2 to 1 hour. You lose some time when the battery tops off (evens out the cells), but it gives you an idea. To charge a battery to full (from empty) in 15 minutes means a charge rate of 4Q. This requires very good thermal management and charging electronics. There is a reason most EVs have around a 1/2 hour 10-80% charge time regardless of battery size (given a powerful enough charger). That means you are charging at the sweet spot of around 1.5Q. The quicker we charge, the higher the Q number, and the worse it is for the batteries. Different chemistries (ie solid state etc) may have a higher Q number - say 3-4. This would mean a charge in 15-20 minutes is possible.
As an example, the Honda E supports 100kW charging, however it still takes around the same time to charge the (similar sized) battery. The peak charging rate may temporarily be higher, but you need to slow down quicker to avoid damaging the battery with excess heat.
