Mini Monster
Ride is much softer with the slightly higher sidewall and all season tires.
Only downside is the speedometer will be off by 2mph give or take. So 45mph is really 47 mph
What tires were on it previously?
The speedometer can be adjusted in the hidden service mode. I think they call it the "correction factor."
205/45/17
That's actually a lot bigger of an increase in diameter than I thought... I'm considering slightly larger diameter tires as well to deal with the dirt roads around here.
Have you noticed any rubbing during sharp turns or on large bumps?
If you haven't seen my old thread on spacers, it answers some of your questions. Cheers!@Mini Monster Have you noticed any significant decrease in range with the larger/wider tires? Would you be able to share any other pictures? Directly from the front to show how flush they are and directly from the side to show how they fill the wheel wells would be very much appreciated!
https://www.insideevsforum.com/community/index.php?threads/wheel-spacers-on-the-se.9829/
Based on my experience with the low rolling resistance tires on my 3 Insight hybrids and my Clarity Plug-In Hybrid, I'm willing to sacrifice a few miles of range to achieve the fabulous handling I get from the Summer performance Hankooks that MINI put on my SE. Every time I read about forum members upgrading their tires, I wonder how hard they drive their MINI Cooper SEs because I drive pretty hard and never reach the stock tires' limits.Thanks! I did actually find that (and used it as a reference for my target offset).
From what I can find in the numerous different wheel threads:
Too bad tire manufacturers don't publish rolling resistance of their tires because that seems more important than size/width/offset/wheel choice
- Offset has a minimal effect on range (from your thread)
- Tire choice has a huge effect on range (from MichaelC combined with your result to remove the effects of offset change)
- Wheel width/tire width has a small effect on range (also MichaelC)
After driving two gen-1, 70-mpg Honda Insights with hard, un-sticky tires for 20 years, the traction the Hankooks provide blew me away. It's amazing if tire technology has improved to the point where my Hankooks can match the low rolling resistance of those eco-Bridgestone Potenza 92 tires (which are still being sold).I don't think you're sacrificing much (if any) range with the Hankooks. The EU tyre labels for the 205/45R17 Ventus S1 evo3 (88W) and the 195/55R16 Ventus Prime3 (87W) show they have a rolling resistance/fuel efficiency rating of 'A', which is the most efficient. Interestingly, those same tire models have different ratings depending on size, load index, and speed rating.
It is possible to have a tire with both low rolling resistance and great handling performance. Unfortunately, it seems like tire manufacturers are focusing on 19" sizes or larger for EV-specific tuning.
