Teddydogno1
I just put in an order for my Mini SE and I'm planning for my own charging and seeing what public chargers are near me.
I knew that there are 3 EVGO chargers at the ACE Hardware right where we get on the freeway (I live in a small bedroom community where we have to get on the freeway to go just about anywhere). They list the price on their website as one charger at $0.29 per minute for 50 kW charging and the other fast charger at $4.95 plus $0.20 per minute. Anyone familiar enough with EVGO to know if that is a membership charge, or a choice to make depending on how much juice you need? If charge for each use, then it seems that about 55 minutes is the break-even point between the two options, which the Mini should really never need.
The only other public charger close by is a stand of Electrify America units at the Walmart about 10 miles up the freeway. For non-members they charge $0.43 per kW/h (or $0.31 with the $4 monthly membership). I think the non-member price works out to about $6.24 to charge an SE from 30% to 80% (half a battery). Does this sound about right? I compared this to a tank of gas in our 40 mpg RAV4 Hybrid and it doesn't seem to favorable.
RAV4: 11 gallons at $3.60 / gal yields a range of 440 miles for $39.60, or $0.09 per mile
Mini: 50% battery is about 60 miles range, so would need about 7.3 30-80% charges to equal the range of the RAV4 at a cost of about $45, or $0.103 per mile at EA. (The math works the same if we assume 120 miles for a full charge range to get 3.67 charges to do the same 440 miles).
Obviously home charging is more cost effective.
Here in WA, PSE charges me a flat monthly "Base Rate" of $7.50. Then the first 600 kWh per month are billed at $0.094437 ea. All kWH over that are "Tier 2" and billed at $0.113903. Then there are several credits relating to Hydro and Wind Power, but no "transmission" charges or anything like that. No time-of-day rates. We always use over 600 kWh per month now without an EV, so it is pretty easy to say the any EV charging will cost the Tier 2 rate, or 11.4 cents.
At this rate, the same 3.67 full charges (or 7.3 half charges) of 29 kWH at home would cost about $12.14, which is way better at $0.028 per mile.
Using this same data again and charging at EVGO, lets assume the same 50% charge takes 36 minutes as stated by Mini... That's 36 min at $0.29 for $10.44, which is a whopping $76.12 for the required 7.3 charges to get the 440 miles. That's over $0.17 per mile. But I think this is wrong because the 36 minute figure is probably not for 30% to 80%.
Does this all sound about right?
Rob
Rob
