I'm moving the conversation from another thread into it's own thread to assist with future member's search for info specifically related to hitches for the mini SE.
Greetings, new member and first post. I just picked up an Iconic SE eBlack a few weeks ago. I ride and needed a solution to carry my bike. I spoke with a sales rep and was told that the hitch that outmotoring sells for an ice cooper S worked for the SE.
Yes, it bolts onto the stock mounts (not really, they needed a bit of grinding to enlarge the mounting holes, and two plastic brackets hanging down from another plastic bumper trim needed to be trimmed), but the 1 1/4" receiver didn't work for me, since my current hitch rack is 2".
The as-sold hitch receiver would have also protruded through the painted bumper skin rather than the black fascia. That, and the 1 1/4" receiver were both deal breakers for me.
I needed to decide whether I was going to build one from scratch or modify the one they sell. So, I bought the outmotoring hitch for the ice cooper S, a 2" steel receiver tube that was 6" long, and went over to a friend's house who's quite handy with an arc welder, to modify the hitch as purchased.
I calculated that with a 1/4in steel plate, and the 2" receiver tube welded to that and the 1 1/4" receiver, the 2" receiver would then protrude just under the lip in the lower fascia. We cut out a 1/4" inch steel plate about the length of the 1 1/4" receiver, but a bit narrower and welded it to the bottom of the 1 1/4 receiver to space it downwards. We then tacked the 2" receiver on for a trial fit, and reinstalled the bumper skin loosely. The receiver didn't stick out far enough so we moved it out another 3/4" in. Btw, we drilled the hold for the bike rack security pin prior to welding onto the purchased hitch.
Another quick trial fit, some primer and gloss black paint, some trimming with a small cutting wheel on the lower fascia, and here it is. My bike rack has a wedge on the mounting surface to reduce wobbling of the rack while driving. With that properly secured, the rack is super solid going down the road with my bike on it, and I don't really notice that my bike is hanging off the back.
If you know what you're doing, the tail lights and rear bumper can be off the car inside of 15 mins, it was simple once you figure out that you have to reach inside the rear opening in the tail light cavity and release some tabs. Takes a bit of careful pulling on the rear quarter moldings, but other than that, very straight fwd removal of bumper skin.
My reply to member Carsten Haase:
Did you happen to get any pictures with the bumper off? Im going to do the same thing as soon as I have time, but probably start from scratch.
I was planning on putting the receiver an inch or so lower so I only had to cut into the lower part of the trim piece but also need a wider hole because I do plan on towing a small trailer (so I'd need a spot for chains + electrical plug)
Here are some more pics.
