The 12V stuff I had still works as before, as far as I can tell.
So I went out and tested/verified the 220105-based max power / regen parameters. Seems to work,
although whatever spreadsheet this came from has it backwards! By simple inspection and the fact
that I started at 90% indicated, it turns out that maximum regen/charge power is bytes Q and R, and the
maximum discharge power to GO with is bytes S and T.
When I started off, still at 90% on the full charge from the dealer, max discharge was at 180 kW. I
thought "hmm, have they upped the available pack power from 2019?" Well, it didn't take long to
settle back down to the 170 I expected. Regen power, on the other hand, started at about 117 and
over the course of driving around, slowly crept up to 170. That was at 70% real, 72% indicated.
I surmise that the two figures would stay at 170 between 30% and 70% SOC, and as charge dipped
even lower the max power/discharge figure would start going down. I've confirmed 70% as one of
those thresholds; I'll try to remember to study it as I get near 30% or less. The two figures have a
pretty clear inverse relationship.
Mind you, I haven't yet full-cycled this new pack, so various limits and values could change after I
do the "full stroke" test. Friday afternoon rush-hour is not the right time to try that.
_H*
