Hutch
If you're in the US, all 20A outlets have the sideways slot on the plugView attachment 12256
I have a plug that looks like that but it's for my air compressor that's 220v
I meant an additional sideways slot on the regular 120V outlet but that probably wouldn't be clear without the picture. A better description would be a sideways "T"
This is where electricity gets fun (or confusing). It's very true that outlet (NEMA 5-20R) is for 20 A receptacle, that means up to 20 A is delivered to the outlet. Since the SE will not take more than 15 A, it can be maximized using a standard three-prong outlet (NEMA 5-15R). But in order to be safe, it needs to be on a 20 A circuit which can only be determined by looking at the breaker panel.If you're in the US, all 20A outlets have the sideways slot on the plug
I don't think there's anything in the receptacle to prohibit draw, except for the melting of parts. The whole idea behind the NEMA plugs is they are designed to limit draw based on their ratings. If you want more amperage, you're supposed to use different prong orientations.Can a 5-15 receptacle run 16A continuous?
Thanks, everyone. I figured out it's on a 20A breaker, but you're right that it would be costly, and in that case I might as well see if I can go L2. So for now, I'll give L1 at 10A a try, and if that doesn't work out well, I know I have a few options. The L1 would be plugged into a 20A circuit with 2 other outlets that are not usually used, but at least now I know that it will be safe to also plug in my Christmas lights to the same circuit (I don't have too many lights!).Yup, just check the panel for 20A breakers. If they say 20 then it’s possible to switch the receptacle to a “5-20” (see Carsten’s picture).
To take advantage it would also require a new EVSE (charge cable).
https://store.clippercreek.com/level1/level-1-16-amp-ev-charging-station-acs-120
Given the cost of this setup, it might be good for someone who cannot install a L2 line for various reasons.
And if you've upgraded to Christmas LEDs, they draw almost no current compared with the old incandescent bulbs.now I know that it will be safe to also plug in my Christmas lights to the same circuit (I don't have too many lights
Already did! I only have four sets of lights that each draw 0.1A, and two inflatables that draw 0.5A. So I'll even have room to expand without having to worry about the load.And if you've upgraded to Christmas LEDs, they draw almost no current compared with the old incandescent bulbs.
Hardwiring is probably better, but I guess I would have to get my wife, or an electrician, to do it. We have 12 gauge wire, which should be fine for a 16 Amp EVSE on a 20 Amp breaker, right? Or would you recommend thicker wire for extra safety over long hours of charging?That 16A level 1 EVSE I linked earlier is hardwire only. I failed to notice that.![]()
Wow that's cool. I was able to see that a charge from 40% to 100% (my typical charging needs) takes 18 hours with the supplied Level 1 cable at 10 A, but drops to a mere 12 hours at 15 A. Might be worth getting a new level 1 cable after all. For comparison, my Level 2 at the full 7.6 kW takes under three hours for the same charging.Not sure if this is in line with this thread but I ran across this the other day.
https://evcompare.io/cars/mini/mini-cooper-se/charging/
Sounds good. But I am wondering if the supplied cable is only designed to draw 10A how can I increase it to 15A? May be I need to buy a Level 1 cable that draws 15A for a 1.8KW output.Wow that's cool. I was able to see that a charge from 40% to 100% (my typical charging needs) takes 18 hours with the supplied Level 1 cable at 10 A, but drops to a mere 12 hours at 15 A. Might be worth getting a new level 1 cable after all. For comparison, my Level 2 at the full 7.6 kW takes under three hours for the same charging.
Yes, you'd need to replace the Level 1 cable with one rated for higher amperage. And since they cost over $200 I've been hesitant to buy one.May be I need to buy a Level 1 cable that draws 15A for a 1.8KW output.
