There is evidence of ICE engineering design rules in the video (i.e., excessive use of steel.) It may take longer for VW to 'get it.' The EPA metrics for the ID.4 suggests the same (@Domenick.)
OK, the reason VW moved all that stuff out front (at the expense of a Frunk), is to give more usable interior space for driver and passengers; the reason for not using aluminum (or flimsy grade steel) for hood, back gate .... is to maintain body integrity, durability, and longevity. I’m sure VW could have shaved a good chunk of weight of their cars at the expense of safety, comfort, ... (and increased mileage), and they would have ended up with a Tesla-like product.The video does show a compromise VW has decided to make. I personally like a good frunk, but I don't think it's something a lot of people coming from gas cars will miss. On the other hand, the MEB platform will sit under a lot of different types of vehicles and VW should have spent the extra money to engineer the empty space up front to allow for a frunk.
He makes a decent point about steel in the hood and weight being the enemy of EVs, but cost is also the enemy of EV uptake so I think it's an ok compromise. Same with the hood struts. With no frunk, that's little need to open the hood, so I don't mind that it have a hood prop.
But that’s exactly why I’m keen to get the ID.4 from Germany, not Waite for a compromised / optimized version from Tennessee. One look at the Passat made in Germany for European market and the ones designed for and made here make my point. Even the battery chemistry for the ID.4s will be different.
Mainly irritable about his inability to deal with the UI. Exactly as you observed, he’s looking for ways to have cheaper manufacturing not better product for the consumer ...... welcome to Detroit’s world.I haven't seen all of his id4 vids yet, but I'm taking his comments with a grain of salt. I don't know suspension, but I don't know if he does either. Many of his comments are about manufacturing for lower cost, which effects VW profits more than it effects the consumer. He seemed really irritable because he hopped in a new car and tried to do a test drive video when he had a meeting to get to. That said, the UI may be crap, and the charging system has known flaws.
Maybe I'm the oddball on EVs.Mainly irritable about his inability to deal with the UI. Exactly as you observed, he’s looking for ways to have cheaper manufacturing not better product for the consumer ...... welcome to Detroit’s world.
BTW, the UI is not crap, the software supporting the UI is crap. The charging system software is being sorted out as we speak, but charging speeds are actually respectable for both AC and DC (11kW, 125kW).
Hello all:
Engineer here w/ some admittedly EV Noob Engineering & Design questions specifically re: ID.4.
All Qs were precipitated by Munro's "Jumper" discussion starting at 10:10 in movie in the OP.
1) On ID.4 are the onboard DC systems "grounded" using the chassis as the reference "negative"; standard in ICE designs?
2) On ID.4, if the answer to #1 is "yes" is the chassis commonly used as a negative conductor; as is also standard in ICE designs?
3) On ID.4 do the various auxiliaries accessories still generally operate at the "standard automotive " 12 VDC?
-- and lastly --
4) In Monro's "Jumper" discussion, what what would be the purpose of the 12 VDC jumper cables he's attaching?
If the EV has no 12 VDC, I can only assume it's because it's main battery is "flatlined" and has gone into some sort of "conserve" mode such that it's no longer feeding the low-voltage / aux DC systems.
In this case, one might think that nothing significant is going to happen until AC [or Fast DC] is re-applied via the charging connection to re-power the onboard rectifiers to charge the battery AND create aux DC.
Please help me to "get up on the governor" here.
Signed,
"Listed" for AWD in Chattanooga
... If it does go dead you can't start the car without jumping the 12v battery. A lot of us on the forum carry a small jumper pack to start the car in case of a dead 12v battery ...
Fastnf:
Thank you for the very complete and informative reply.
I fully understand the design imperative to NOT allow the main traction motor battery to be run-down by a low-VA - but extended-duration - Aux power draw.
But I'm a bit surprised that there isn't a "built-in / under-the hood" mechanism to allow temporary utilization of the HV system to power-up the DC-to-DC converter to "self-jumper" the 12 VDC Aux system.
That said, I'm sure there is a good technical rationale; I suspect it's all related to having the 12 VDC Aux (control power) to begin with.
[An EV take on the "Chicken or Egg" paradox]
Thanks again.
... So the relays that let power out of the battery are meant to be powered externally ...
